-   -   Is it OK to screw into plaster. (http://www.diychatroom.com/f101/ok-screw-into-plaster-106426/)
acerunner 06-02-2011 10:01 PM
I have a very old traditional style fireplace shaped out of plaster. I've remodeled the rest of the house for a more modern style, so I want the fireplace to match. I thinking something with clean straight lines, so my idea was simply to wrap the existing fireplace with drywall to cover the detailing that made the fireplace look so traditional, and mud it to give it it's straight lines. However, i'm not sure if screwing drywall into plaster is a good idea. Any ideas?
oh'mike 06-03-2011 05:40 AM
A question or two----What kind of plaster?--Wood lath with plaster or plaster over gypsum board?
If possible use drywall adhesive and a minimum of screws----often the screws will pop a chunk of plaster loose--causing a hump under the new drywall.--Mike---
acerunner 06-03-2011 11:09 AM
I remember seeing all white plaster from the backside when the walls were open. Unfortunately the walls are closed up now and I can't get a closer look. I don't think there is wood lathe, but I didn't see gypsum board either. It looked more like a hollow plaster shell, which doesn't quite make sense now that I mention it. so I must have missed something.
oh'mike 06-03-2011 06:15 PM
Plaster over gypsum is much less likely to chunk out with screws---Wood lath can be a big problem--
Use adhesive and only enough screws to keep the new Drywall in place as the glue sets.--Mike---
oldrivers 06-03-2011 09:03 PM
take an awl and try finding the studs. we do it quite a bit but you do need to be careful not to get a broken chunk of plaster pinched between the rock . screws dont seem to grab lath very well it usually splits, hit the studs .
