Off Angle Drywall Hanging/finishing? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-13-2008, 05:30 PM   #1
Rewards Points: 24
off angle drywall hanging/finishing?
I am finishing my attic and am hanging the drywall. I have a flat ceiling, the roof joists as part of the ceiling that are on an angle and then the walls. So the walls go up 48" and then the joists on about a 45 degree angle and then the ceiling. Hopefully that makes sense! What is the best way to hang the drywall so you get a straight line at the angles. Also what is the best tape to use when finishing this and is there any special procedure when finishing it. Thanks for your help
ponch37300 is offline   Reply With Quote
Old 07-13-2008, 09:44 PM   #2
Registered User
Termite's Avatar
When hanging the rock, I'd say just butt the pieces together and don't try to cut some fancy bevel. Use paper tape at the seam, and mud it conventionally. Bed both sides of the tape in mud, and let it dry. When finishing the joint, just do one side per day. Wall, then ceiling, etc.
Old 07-14-2008, 06:13 AM   #3
You may want to use a composite tape such as this to keep the angle a little straighter:
http://www.all-wall.com/cgi-bin/sh00...512#a1_2110512
jerryh3 is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 04:12 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 08:21 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
