Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-21-2011, 07:15 PM   #1
NYC apartment walls
I just moved into a building in NYC that was built in the late 60s and I wanted to mount my 42" plasma. I drilled a few test holes after I used a stud finder and discovered the walls were about 2.5" thick. The drill bit went right through, I now have a peep hole to my bedroom. The other hole went in 1.25" and stopped. The dust looks like drywall/clay dust. The walls seem thick though, I can't hear people talking in the other room.
Any ideas what kind of walls I'm dealing with?
Should I abandon all hope of mounting my TV or anything for that matter? I was hoping to mount some shelves also.
whooops is offline   Reply With Quote
Old 12-21-2011, 07:20 PM   #2
NYC apartment walls
Sounds like you have drywall attached to strapping that's attached to brick walls.
Old 12-22-2011, 01:08 AM   #3
Architectural Designer
AGWhitehouse's Avatar
NYC apartment walls
probably have stud walls with the studs turned sideways. 1/2" gwb, 1-1/2" stud, 1/2" gwb, gives you a 2-1/2" wall. It's pretty common in city settings to use this type of non-load bearing wall as city real estate is big $$$....so wasting it with dead wall space is a waste...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 12-22-2011, 12:40 PM   #4
NYC apartment walls
1/2" gwb, 1 1/2" stud, 1/2" gwb, makes sense but I didn't know that was possible. So, would it be safe to mount a 95lb. TV on?
Thanks for the tips.
Old 12-22-2011, 02:15 PM   #5
NYC apartment walls
Hard to say from where I'm sitting...
Tags
mounting, plasma, plaster, tvs
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 10:41 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
