NOT Using Green Board... - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 11:44 AM   #1
NOT using green board...
HI all. I'm about to demolish (partly) a bedroom that I'm turning into a second bathroom. I'd very much like to leave some of the existing drywall intact, however it's not green board. Is there a legitimate sealing compound, paint, or ??, that I can apply to the old surface that'd make it impervious and thus safe to leave on? Hope so. Thanks for any replys...
Alvis is offline   Reply With Quote
Old 06-29-2010, 12:10 PM   #2
Rewards Points: 3,130
Green board is no longer approved for damp applications - it's actually worse that the regular stuff.
Old 06-29-2010, 12:33 PM   #3
DIY staff
Rewards Points: 7,174
If you are concerned with the walls and ceiling away from the tub/shower regular drywall is fine.
Proper painting will protest it.--Mike--
Wet areas need durrock or other approved backer.
Old 06-29-2010, 10:20 PM   #4
Registered User
Rewards Points: 4,912
Be sure to notify local B.D. of the added bathroom, especially if on City sewer.......
Be safe, Gary
Old 07-01-2010, 11:33 AM   #5
We are rural and on a septic system GBR. The increased flow because of two br's will be minimal except when family members are there. I plan to use cement board where the shower will be and the rest regular board I guess. Thanks guys. Any additional feedback is appreciated. I've learned a lot from this DIY forum.
Old 07-01-2010, 02:25 PM   #6
if you use cement board put roofing felt between it and the studs. cement board can transfer moisture through it
racebum is offline   Reply With Quote
The Following User Says Thank You to racebum For This Useful Post:
rtoni (07-09-2010)
Old 07-01-2010, 04:14 PM   #7
Never seen that done. I've got two houses done otherwise... hmmmm, opps!
Old 07-02-2010, 03:31 AM   #8
might not be oops at all, a lot of guys don't do it. it's just a cheap backup if any moisture ever does get in seams or transfer through. one roll of $20 felt will do a lot of work
Old 07-02-2010, 04:04 AM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
I hope not much
chrisn is online now   Reply With Quote
Old 07-09-2010, 11:30 AM   #10
Rewards Points: 270
new bathroom on my list too - and I have leftover felt sitting around - that's a great tip - might as well use some of it up - thanks...
rtoni is offline   Reply With Quote
Old 07-09-2010, 11:32 AM   #11
Rewards Points: 270
Is the blue board (humitek?) any better, e.g. worth the extra $$$?
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 07:29 PM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 03:20 PM
Green Board over Vapor Barrier? Pineapple Remodeling 7 11-18-2008 10:21 AM
Durock or Green Board oxicottin Remodeling 7 06-12-2008 07:51 PM
Preping green board for tile? stbo2000 Remodeling 9 02-06-2008 10:40 AM
