Not sure about using vapor barrier
4K views 6 replies 6 participants last post by  acerunner
We have enclosed a section of our screened-in porch to make a mudroom/laundry room. We have heard different opinions on whether of not we need to use a vapor barrier under the drywall. We live in northern IN where the winters are cold. What is the right thing to do and if a vapor barrier is needed, do we use it on the ceiling also?
There are many varied opinions these days. Most people are concerned about vapor barriers in basements where concrete or block foundations are involved. I wouldn't use one on wood framed walls. I use glue and nails (you can opt for screws) on wood framing. The vapor barrier over the studs would negate the use of adhesive which adds strength and reduces nail/screw "pops"....
#4 ·
I agree with using faced insulation and was assuming the OP was asking about the plastic. I have to disagree for the reasons stated above from the drywall perspective. It's not done in this area....
