Not Screwing Board Edges In Wall Corners? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-15-2010, 05:49 AM   #1
Question
Not Screwing Board Edges in Wall Corners?
I've heard some drywallers talking about not screwing the edges of the boards on walls and/or in wall corners (Letting them "float".)
Is there anything to that? I always thought all edges should be tightly screwed down.
TomBrooklyn is offline   Reply With Quote
Old 01-15-2010, 07:36 AM   #2
Yes, it allows wood movement without cracking at the corners. A sheet is placed in the corner, walls or ceiling, and the second sheet is butted up against it. You screw the second sheet fully, but the first sheet is not screwed in the corner.
For ceilings you need good backers like the walls but the perimeter is not screwed.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 01-16-2010, 11:17 PM   #3
artlover13060's Avatar
Could you please elaborate on not screwing the perimeter. I am just starting a ceiling but have only done the soffits so far.
artlover13060 is offline   Reply With Quote
Old 01-16-2010, 11:53 PM   #4
Registered User
Rewards Points: 4,924
Floating corners, figure #2: http://bestdrywall.com/files/ReduceCallbacks.pdf
Taken from: http://www.gypsum.org/pdf/GA-216-07.pdf Which also has priming before and after texturing, and most other answers to questions about drywall.....
Be safe, Gary
Dry wall or cement board? Or both? newdiyselfers General DIY Discussions 4 09-23-2009 05:52 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Rounded wall corners Jiffner Painting 6 06-08-2007 09:58 PM
wall tile/Hardee board help irlizard Remodeling 3 07-09-2006 10:45 PM
