Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 09-07-2012, 10:57 AM   #1
non-90 deg out angles
Can somebody give instruction how to make a straight line on an out corner that is different than 90? E.g. should i bend a regular corner bead or use the metal reinforced tape? Also, how to handle the inevitable gap between two sheets when the angle is >90?
Old 09-07-2012, 11:40 AM   #2
i would use the metal reinforced tape. on outside corners we always ran the first piece flush with the outside corner and let the sheet on the other side overlap the first one, shaving it down flush with the first one if needed leaving no gap at all.
The Following User Says Thank You to DannyT For This Useful Post:
amakarevic (09-07-2012)
Old 09-07-2012, 09:14 PM   #3
ultraflex 325 no coat http://www.no-coat.com/NO-COAT/ARCHI...cts/ULTRAFLEX/
princelake is offline   Reply With Quote
The Following 2 Users Say Thank You to princelake For This Useful Post:
amakarevic (09-07-2012), ToolSeeker (09-20-2012)
Old 09-20-2012, 06:07 AM   #4
I agree with PrinceLake- ultraflex 325. Though perhaps unnecessary, I always fill those inevitable gaps with a setting compound before applying the ultraflex. No matter how good/strong the corner bead is, is can only withstand so much without something solid behind it.
designSTL is offline   Reply With Quote
corner bead for non-right angles amakarevic Drywall & Plaster 2 07-17-2012 08:19 PM
cutting mouldings that are not right angles it99 Carpentry 7 05-04-2012 01:34 PM
Need some quick help with coffin angles. DangerMouse Building & Construction 6 01-27-2010 04:40 PM
Can a septic line make right angles? Randell Tarin Plumbing 7 01-26-2008 09:01 PM
Angles for cutting crown mouldings sjrhome Carpentry 14 04-13-2007 08:14 AM
