No Nail/screw Edge - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-12-2010, 06:31 PM   #1
No nail/screw edge
I am hanging a ceiling and have a small section that I can not put blocking.
My question, How far can I hold a screw back and "float" the edge?
The ceiling meets a bulkhead and there is Pex (flexible plumbing, 9 lines of it) running right beside the top edge of the bulkhead.
I have 11 inches from the bulkhead to the nearest nailing edge.
My thought is that the piece on the bulkhead could support the ceiling piece which would be screwed in 11 inches back.
Any standard "rule' that applies?
\Thanks in advance.
will
williamwiens is offline   Reply With Quote
Old 11-12-2010, 06:40 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Will, Can you post a Pic?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-12-2010, 08:37 PM   #3
DIY staff
Rewards Points: 7,174
The wall sheet will hold up the ceiling sheet --you are fine --16" is the accepted distance from the wall .
With truss roofs you are not supposed to screw within 16" of a wall.--Mike--
Old 11-12-2010, 09:13 PM   #4
Thankyou. I have always wondered what the max tolerable would be.
I am more comfortable with it now.
Cheers,
W
The Following User Says Thank You to williamwiens For This Useful Post:
oh'mike (11-14-2010)
Old 11-19-2010, 06:57 PM   #5
Drywall contractor
Rewards Points: 1,070
Less is better but as Mike said, 16" is acceptable as long as the wall supports the ceiling.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-20-2010, 07:50 AM   #6
it all worked out quite well actually. I added some 1x2 blocking where I could and still used the bulkhead pieces to hold up the ceiling pieces.
It ended up that the screws were only 9 inches back.
Pretty secure and I'm not so worried about my joints cracking now.
Thanks for the info.
Axecutioner-B (11-20-2010)
Install gutter apron or D style drip edge on existing roof? sophie10 Roofing/Siding 6 07-13-2015 09:04 AM
roof drip edge billygale Roofing/Siding 9 10-24-2010 02:19 PM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 10:49 AM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
