-   -   Next phase- drywall! (http://www.diychatroom.com/f101/next-phase-drywall-126548/)
federer 12-13-2011 06:16 PM
Hi fellow frustrated members-
so most of you probably don't know this but i have been making threads as we progress through our never ending remodel, and we are finally at the drywall phase!
now my question is given the crazy ceiling we have, is 1/2in normal drywall sufficient? also, do you need to install furring strips or can you just screw directly to the joists? i have never done drywall before so i am trying to read up on it. any other advice is welcomed. thanks!
http://i892.photobucket.com/albums/a...-59-35_717.jpg
federer 12-13-2011 06:18 PM
http://i892.photobucket.com/albums/a...-57-07_526.jpg
the joists run straight then angles down
http://i892.photobucket.com/albums/a...-54-45_953.jpg
titanoman 12-13-2011 06:46 PM
Must ceilings are 5/8" (fire code).
Sent from a Samsung Galaxy S2
joecaption 12-13-2011 06:51 PM
5/8 is used so the ceiling will not sag. Make sure to use screws not nails.
That's one messed up ceiling right now. I'd pull a string across it in a few place to see how flat those rafters are.
I'd borrow or rent a drywall lift, so much easer to do a ceiling that way. With a lift, one man can install a 4 X 12 sheet by there self and have far less seams.
federer 12-13-2011 07:02 PM
thanks for the reply guys!
so i need 5/8th not 1/2in. also, i have never done this before. can i just screw the sheets up myself, and have someone else finish it? finishing just means taping the seams and mudding right?
federer 12-13-2011 07:07 PM
also, should adhesive be used in addition to screws?
joecaption 12-13-2011 07:10 PM
Simple enought to hang and finish, it just takes a little practice to get good at it.
First you have to figure out the best way to run it and all seams must meet in the middle of a rafter so take a few min. to see where the sheet will end up, it's easy to just cut some off if the rafters were laid out wrong, you never want to end up with just a narrow strip any place.
titanoman 12-13-2011 07:12 PM
No glue. Maker sure the screws counter-sink 1/16" without tearing the paper. Finishers get very upset if they have to carry a screw fun around with them.
federer 12-13-2011 07:13 PM
yea the ceiling is all messed up. how do i fix it if it's not even all the way across? so i cant just line them up and cut what i need for the remaining space?
federer 12-13-2011 07:15 PM
so no glue. whats a screw fun? screw gun? i am thinking about hanging it myself and have someone finish. also, how do you do the edges? you need to use one of those corner metal pieces right
titanoman 12-13-2011 07:18 PM
The tapers will put metal where ever they want it, like where the ceiling goes from flat to angled.
federer 12-13-2011 07:26 PM
sorry i dont know anything here-so the metal pieces are for lining up the edge of the drywall, and can be put anywhere not just at the corners?
titanoman 12-13-2011 07:30 PM
I think you're talking about "corner bead", for wall corners. The reason they probably would use it where I said is because it makes for nice straight lines at the transition when taped.
federer 12-13-2011 07:32 PM
yea for where the drywall meets the wall. but you are saying they can use it at the spot where the angles forms too right? also, what kind of screws do i use? tehres different kinds of drywall screws right
titanoman 12-13-2011 07:36 PM
No metal where the ceiling meets the wall. Only where the ceiling goes from flat to angled. Standard 1 5/8" drywall screws.
