Newbie: Question About Hanging Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 04:45 PM   #1
Newbie: Question about hanging Drywall
When hanging drywall what is the bst way to hang the sheets. Horizontally or vertically. Why does it matter. I am having a lot of problems with my cuts as well so vertically would be easier but was told not the best way.
Yedi015 is offline   Reply With Quote
Old 01-02-2012, 05:02 PM   #2
Rewards Points: 13,750
Horizontal and 12' sheets when ever possible, far less seams and the seam you will need to finish will be right in front of you.
The ceiling goes in first. Then the top piece so it's tight to the ceiling.
The only cuts you should need to make are at the ends of the runs.
Use a shape utility knife and a drywall square so it can be cut in one pass.
You only need to cut through the paper, go on the other side and hit it with you knee to snap it. Then just cut throught the paper on the other side.
When making your cuts do not try and make it so tight you have to force it in place. Leave a gap.
When cutting out for outlet boxes I do my layout using the drywall square then cut it out with my ossilating saw. Far less dust and more control then with a Roto Zip.
luckyrabbit (01-04-2012)
Old 01-02-2012, 05:44 PM   #3
Registered User
Rewards Points: 5,516
5/8" is 3 times stronger as drywall has a "grain" to it, 1/2" is 2-3/4 X's stronger; https://docs.google.com/viewer?a=v&q...U1o3kfoOlKl-7Q
I score the paper, snap it, cut the back-paper, all from the finished side. (Giving Joe a hard time....) (Joke) Are you using a drywall square and a sharp knife?
Gary
Old 01-02-2012, 06:06 PM   #4
Drywall
I am however I did forget to mention it is a family room downstairs in my house and the ceilings are about 7' thats why I am cutting horizontly. also is it necessary to leave a gap at the floor?
Old 01-02-2012, 06:24 PM   #5
Needs to be 1/2, if not moisture will wick up. The cut needs to be on the bottom. Never have cut edges where theres a but joint. Cuts need to be at the bottom and in the corners.
PS I do my cuts with the drywall standing up and my arms are short so I have to walk around to cut the back side.
Old 01-02-2012, 06:38 PM   #6
Rewards Points: 582
we keep our board about 1/2 to 3/4 inch off floor to keep off moisture.
Old 01-02-2012, 06:44 PM   #7
Go buy yourself a floor kicker. It's set on the floor and used to lift the drywall up off the floor. It's about $5.00.
One the ceiling and walls if you use drywall adhesiveou can use less screws.
Always use screws not nails.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
ben's plumbing (01-02-2012), TurboDIYer (01-06-2012)
Old 01-02-2012, 06:47 PM   #8
Rewards Points: 582
Hey joe joe thats called a drywall kicker:thum bup: ben
Old 01-02-2012, 06:51 PM   #9
Where was I when we had the vote on who to pick on tonight?
Bring it on I can take it and your days coming. LOL
Old 01-02-2012, 06:54 PM   #10
Rewards Points: 582
been there done that....
Old 01-02-2012, 07:26 PM   #11
retired union carpenter
Send a message via Yahoo to coupe
horizontal is best direction to hang drywall, cut so cut edges are 1/2-5/8 off floor. 5/8 drywall is much stronger than 1/2 horizontal hanging keeps walls much straighter that vertically hung. which is most noticeable after baseboard is installed, you'll see the waves more if vertically hung? a good heavy bead of caulking or acoustical sealant along floor filling the crack will help keep air out/in as well as ants and small bugs.
I don't typically use a drywall square, seldom are they right! unless you buy an expensive one? I usually use my finger running along the edge of sheet and knife blade on tip of tape measure, bend back and snap, then use drywall rasp to knock off rough edges at joints. you've no need to worry about rough edges along floor if keep it raised a bit. you'll rub a blister on your finger running along edge until you've built up a callus. it wont hurt long!
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 01-03-2012, 03:01 PM   #12
TY so much for your help guys. I will try what u said. Cant wait to try and tape. Oh Joy
Old 01-03-2012, 04:01 PM   #13
when you get ready to start taping, read my post to "recommend good book" now on page 2 of this forum. I wrote in precise detail how to go about taping and finishing drywall
hope it helps you?
newbie question..removing plaster to drywall jstar571 Drywall & Plaster 23 01-11-2012 04:38 PM
Hanging Drywall DUDE! Drywall & Plaster 1 08-21-2010 05:04 PM
Drywall corner question Anne Drywall & Plaster 2 11-13-2009 03:50 PM
Drywall question Bodrey Drywall & Plaster 6 10-23-2009 10:50 PM
drywall question for the pros steve1234 Drywall & Plaster 8 07-28-2008 10:56 PM
