Newbie Needs Help With Ceiling / Drywall Repair - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-18-2013, 02:37 PM   #1
Newbie needs help with ceiling / drywall repair
Hi Everyone
i'm trying to tackle this project myself and it'll be my first time drywalling the ceiling as a homeowner.
there was a water leak which has now been fixed.
i've replaced the drywall in the large hole but not the small hole yet. as you can see from the photos (hopefully i attached correctly), i didnt do a great job and there are some gaps and not 100% flush with the ceiling. as a DIYer, would it be easier if i use mesh rather than taping the joints? i figure my process would be:
1. mesh or tape
2. add 2 layers of compound (slight sanding in between if necessary)... can i use a 4-5" scraper vs a larger trowel for this?
3. sand flat as possible after 2nd layer is dry
4. prime entire area
5. use texture spray (i doubt i can get it to match that well but i am ok with that)
6. paint 1 coat (with same ceiling paint), maybe 2 coats if necessary and feather into the rest of the ceiling
i dont expect it to be perfect but for the low cost of materials, i figure i give it a try and hope that it turns out "reasonable"
if it turns out unacceptable to my wife and i, we'll just get someone to do it professionally.
for the small hole, can i just put 2 screws into the replacement drywall?
hopefully some of you can give me some tips. thanks in advance!
Vancouverguy
Newbie needs help with ceiling / drywall repair-ceiling.jpg
Newbie needs help with ceiling / drywall repair-ceiling-2.jpg
vancouverguy is offline   Reply With Quote
Old 07-18-2013, 06:59 PM   #2
DIY staff
Rewards Points: 7,174
You have the drywall upside down in the big patch---white side out---
I always use paper tape--the mesh is okay I suppose but I have better results with paper---I suggest you get a small tub of 'multi-purpose' green lid---that one is a setting compound and contains glue.
Once the paper is set --then top it with two or more thin coats of the same mud---or switch to the 'light weight' blue lid for the final top coats--Blue lid is softer and much easier to sand.
Ceiling patches often need to be feathered out a long way to prevent the patch from being seen--some times 24" or more----so be patient--several thin coats always look better than one or two thick ones---
ben's plumbing (07-19-2013)
Old 07-18-2013, 07:19 PM   #3
shoot, i'll have to flip it around. thanks
Old 07-18-2013, 07:32 PM   #4
Rewards Points: 582
yep agree with mike we use paper tape also..but we prefill any large gaps with a fast set mud first like a 20 minute dry time .then tape and feather out as mentioned 2-3 thin coats at least 24" wide ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (07-19-2013)
Old 07-19-2013, 07:42 AM   #5
Rewards Points: 6,034
With the big patch what you have are 4 butt joints and as stated it will need to feathered out wide, 2 coats probably won't be enough. And you need a couple drywall knifes an 8" and a 12" should work.with that large a patch and multiple coats I would go ahead and get a bucket. Use paper tape, not mesh. Yes 2 screws should work for small patch. Not a bd idea to pre fill the gaps with USG easy sand in the white bag. It's a powder you mix with water and is stronger than joint compound, just a little insurance, as large repairs tend to crack over time. I would suggest 45 minute.
Old 07-19-2013, 05:10 PM   #6
Old School
Willie T's Avatar
I use no tape at all.
1. Square up your hole
2. Cut a piece of D/W 1" larger than the hole
3. Score the piece, on the back, the size of the hole (maybe a tad smaller)
4. Peel off the board, leaving the paper there
5. Score and peel off a 1" strip of paper around the hole, (maybe a tad LARGER) and remove the paper. (Your patch flap edges will sit down in this peeled-off strip)
6. Slather up the areas where the patch piece will fit into the hole (and all the peeled paper edges) with D/W mud
7 Slide the patch into the wall hole, and let it set up (make sure it is flush and smooth)
You can go back after this has set up, and fill in any edge shallows.
Newbie needs help with ceiling / drywall repair-dry-wall-patch-1.jpg   Newbie needs help with ceiling / drywall repair-dry-wall-patch-2.jpg   Newbie needs help with ceiling / drywall repair-dry-wall-patch-3.jpg   Newbie needs help with ceiling / drywall repair-dry-wall-patch-4.jpg
Willie T
The Following 2 Users Say Thank You to Willie T For This Useful Post:
gregzoll (07-19-2013), Nailbags (07-19-2013)
Old 07-19-2013, 11:02 PM   #7
Rewards Points: 626
just what I would have said
Nailbags is offline   Reply With Quote
Old 07-19-2013, 11:31 PM   #8
Rewards Points: 6,652
Problem with that, it only works for small patches like in the second picture, not large section.
The Following User Says Thank You to gregzoll For This Useful Post:
ToolSeeker (07-20-2013)
Old 07-20-2013, 07:09 AM   #9
correct.
Old 07-20-2013, 08:43 PM   #10
Old School
Willie T's Avatar
Where'd you get that idea?
Willie T
Drywall over open beam ceiling and venting daluu Remodeling 4 11-07-2012 12:54 AM
drywall or sheetmetal ceiling drmax Building & Construction 12 09-21-2012 08:15 AM
Best way to install drywall on uneven ceiling Fred_ Drywall & Plaster 7 11-28-2011 08:54 PM
drywall ceiling repair after bathroom fire help nilewaves Drywall & Plaster 9 06-07-2011 03:33 PM
Popcorn Ceiling Repair CecszaR Painting 7 08-28-2009 03:37 AM
