Newbie In Need Of Drywall Replacement - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 07:34 PM   #1
Newbie in need of Drywall replacement
Victim of the Hurricane ... is drywall hard or expensive to replace????
Donica is offline   Reply With Quote
Old 09-13-2011, 08:00 PM   #2
Gymschu's Avatar
Rewards Points: 502
Not really difficult at all, although finishing the joints can be a challenge sometimes. Expensive? Probably after demand goes up after a Hurricane, but, usually it's not that expensive.......depending on your location........$7 - $10 per 4 x 8 sheet.......maybe a bit less in some locales.
Old 09-13-2011, 11:16 PM   #3
Rewards Points: 5,336
It depends on how much you're talking about?
Ron
B. Franklin 1759
Old 09-15-2011, 12:37 PM   #4
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
1. get the correct thickness to match your current drywall - 3/8", 1/2" or 5/8".
2. greenboard for bathrooms and high moisture areas.
3. about $6 a sheet for 3/8" here, varies with thickness.
4. it can be heavy, bring a friend and a pickup truck.
5. it's pretty easy to cut and install (except ceilings), mudding and taping is the worst part (for me anyway).
Oh-Fudge is offline   Reply With Quote
Old 09-17-2011, 06:41 PM   #5
Drywall contractor
Rewards Points: 1,070
I'd have to agree with "depends on how much" you're talking about. If it's the majority or all of the house, I'd recommend hiring it out.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Question about putting up drywall CZ DIY Building & Construction 5 02-25-2010 10:41 AM
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 11:05 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
