Newbie Mudder - Help! - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-22-2010, 06:31 PM   #1
Rewards Points: 160
Newbie Mudder - help!
First time at mudding drywall and I thought I got the seams pretty good...I painted and then noticed I need to touch up some spots...
Sanding it makes it worse, can I just mud over the painted areas and sand and then repaint?
What do i do?
hellothere123 is offline   Reply With Quote
Old 12-22-2010, 06:44 PM   #2
You have to prime where you touch up or it will flash
dvatt is offline   Reply With Quote
Old 12-22-2010, 07:02 PM   #3
Yes you should go over it some more then resand if needed prime and paint. Many times after you prime you can see the imperfections much easier and can then do another quick coat then reprime so you arent wasting paint or time.
As a first time mudder, if you only have a few spots to fix then I'd say youre doin good It may help too to thin the mud down a bit with just a small amount of water on your finishing coats.
Cmudr1 is offline   Reply With Quote
The Following User Says Thank You to Cmudr1 For This Useful Post:
oh'mike (12-22-2010)
Old 12-22-2010, 08:26 PM   #4
Stay-at-home GC
In general, once you prime or paint you will have no luck sanding down high spots. Very important to get all of the ridges and bumps down before primer. Once the primer goes on, you can go back and fill and sand any depressions.
CplDevilDog is offline   Reply With Quote
Old 12-30-2010, 08:42 PM   #5
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
My advice, never finish or texture yourself
Leave it to the pros. they know what looks good, the diy. never does it right. no offense. I have seen it a thousand times over.
stoner529 is offline   Reply With Quote
How to replace a section of drywall? (Total Newbie) abefroman Drywall & Plaster 4 08-01-2010 11:17 AM
Newbie help lionround Electrical 1 03-21-2010 12:39 PM
Newbie needs help in wiring humidifier. gm2685 HVAC 3 11-13-2009 11:40 PM
SW Ohio Newbie JACC0811 Introductions 2 03-22-2009 02:37 PM
Newbie is amazed-you seem nice! scottyoung Introductions 1 08-03-2008 02:35 PM
