Newbie Drywaller - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 12:15 PM   #1
Newbie drywaller
I am about to put drywall up in my basement. The ceiling is just under 8 ' so i am running horizontal around the room on the walls. I have one wall that is around 30' wide. My question is do i have to stagger the panels on the wall. Is it really necessary for strength or can i just stack them so the butt joints run from ceiling to floor. There so many different opinions, I would prefer not to stagger as i am having a professional taper do the seams. Thanks, any additional advise would be great or photos of your layout prior to mud and taping.
mort5029 is offline   Reply With Quote
Old 12-13-2010, 02:08 PM   #2
Handyman
Rewards Points: 512
If you don't stagger the butt joints, you're taper will yell at you!
Better yet, someone earlier (I think it was ol'mike) posted a neat way to install butt joints-and you can have a continuous seam...check this out.
http://www.finehomebuilding.com/how-...tt-joints.aspx
canadaclub is offline   Reply With Quote
The Following User Says Thank You to canadaclub For This Useful Post:
STL B. (12-14-2010)
Old 12-14-2010, 06:48 AM   #3
Next Time...New Build
Rewards Points: 150
If your ceiling is just under 8 feet, why not just hang the sheets vertically and eliminate the need for any butt joints?
RickyBobby is offline   Reply With Quote
Old 12-14-2010, 08:04 AM   #4
Rewards Points: 256
I seccond the vote for no butt joints. Hang them vertically.
Cut the sheets one inch shorter than the floor to ceiling height.
They sell a lifter device to use you foot to raise the sheets to the ceiling.
You should also discuss the hanging strategy with your tape guy. This will certainly effect the amount of work (Price) there is for taping.
michaelcherr is offline   Reply With Quote
Old 12-14-2010, 09:19 AM   #5
Rewards Points: 150
Thats a slick trick thanks for posting it, Butt joints give me hell.
STL B. is offline   Reply With Quote
Newbie here SMurray Introductions 0 10-22-2010 09:21 AM
Newbie needs help in wiring humidifier. gm2685 HVAC 3 11-13-2009 11:40 PM
newbie HVAC troubleshooting elm66 HVAC 1 06-22-2009 08:38 PM
15 year old deck, newbie, ouch! Theron D Painting 7 08-25-2008 10:05 AM
Newbie is amazed-you seem nice! scottyoung Introductions 1 08-03-2008 02:35 PM
