Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-02-2013, 07:44 PM   #46
New Project First Timer on Dry-Wall
i never use the tape with all the little hole in it. it sucks. i only use cgc paper tape. and i've never heard anybody wetting the tape. i've never had any issues with putting dry tape on. you can use any premixed compound for bedding tape but you take a chance getting bubbles. i use only green lid tape for bedding tape.
princelake is offline   Reply With Quote
Old 03-03-2013, 12:33 PM   #47
Prince if you wet the tape the way he says it almost eliminates air bubbles under the tape.
ToolSeeker is online now   Reply With Quote
Old 03-03-2013, 12:57 PM   #48
Originally Posted by perrytradesman View Post
Wow,reading some of the replies if your not a taper maybe would be best not to give advice...submerge the paper tape in water no joke it has tiny holes in it and the holes open up more when wet
Unless that technique is published in a book or is in the instructions that come with the materials, I'd not do that. The manufacturers of paper tape with holes surely put thought into the proper hole size. Someone claimed that thinning the mud isn't necessary, and now it's claimed that it's good to totally wet the tape. Complete opposites. I suggest taking a book out of the library. That's what I did.
Dorado is offline   Reply With Quote
Old 03-05-2013, 09:22 PM   #49
Well, I am no professional taper but this is what I have done. I have installed and taped probably 500 sheets of drywall.
There is a product for inside corners called Shur-corner. It keeps a great inside straight vertical corner. It is embedded with aluminum and works great. 1 coat to put it up and then 2 coats to finish -Done.
Outside corners I used to use the metal corner bead. I recently,have moved to the vinyl simply out of ease. Spray glue and its not moving. It also accepts a bump or 2 a little better than the metal corner bead does. In addition I like to use the rounded bullnose on corners that will get a lot of traffic. Also gives the areas a softer feel, paints up nice, and my customers have liked it.
I always start with green lid and finish with the blue lid. I rarely have gaps bigger than 1/4" so filling is not that big of a problem(I am not perfect but I try not to leave big gaps in my drywall)
Just myn2 cents. The pros are way better than me, so .....
brucem609 is offline   Reply With Quote
Old 03-06-2013, 11:40 AM   #50
OK if you ask most pro's about wetting the tape they will say NO. But remember when pro's go in to do a house they have all the tools like mud boxes and bazookas. Usually 1 guy puts it on and another comes along right behind and takes it off. Also they use hot mud on their first and sometimes 2nd coats. Now the DIYer usually does this by himself and he gets a bucket of All Purpose and goes at it. The problem being if he uses the mud right out of the bucket and does not thin it, it becomes thick and hard to pull, and to get smooth under the tape. This can also happen if he gets a little slow, it can start to thicken. If you get high spots under the tape and it dries they are hard to deal with. You really can't sand them down because you will have to sand thru the tape. Now if you wet your tape and pull it between your fingers to get the excess off it won't be much wetter than when you put it over wet mud or you put wet mud on top of it. And it gives you the advantage of being able to get a nice smooth line under your tape.
Old 03-10-2013, 08:30 AM   #51
All right got some pic's of my project before I start, I'm using my Dry-Wall Jack for a coat rack for now and the plastic that I was told by the inspector that has to be removed before I hang Dry-Wall.
New Project First Timer on Dry-Wall-000_0006.jpg   New Project First Timer on Dry-Wall-000_0007.jpg   New Project First Timer on Dry-Wall-000_0009.jpg
bote110 is offline   Reply With Quote
Old 03-28-2013, 11:30 AM   #52
Ok a couple of questions:
Lows has "paper tape" that is self stick has anyone tried , is it any good? They also have inside corner bead that's made with paper and metal?
Should I fill gaps first that are 1/8 inch wide then sand it before laying tape? I have some powder mud {couple of cups} of 45 an 90 set to fill the gap's with
Old 03-28-2013, 12:05 PM   #53
Have never seen self stick paper tape don't see how it could work paper tape has to have mud under it and it wouldn't be possible. Also have seen the paper and metal corner bead but only for outside corners. And no you don't have to fill or sand gaps that small your base coat will fill them
Old 03-28-2013, 07:41 PM   #54
http://www.walltools.com/hyde-joint-...erforated.html
It's like this made of paper you peel and stick. Don't know the brand name that Lows sells it's not on there web page.
Old 03-28-2013, 09:23 PM   #55
can someone help me?
john123123 is offline   Reply With Quote
Old 03-28-2013, 09:35 PM   #56
Yes you can hang it vertical.
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 08:49 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Wiring an Itermatic Wall Timer in a 4 way stitch SunnyInFlorida Electrical 8 04-28-2011 12:15 AM
How to diagnose problems with wall kahlan General Discussion 5 10-22-2008 10:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
