New Project First Timer On Dry-Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-15-2013, 09:46 PM   #1
Rewards Points: 141
New Project First Timer on Dry-Wall
Will this is my first time in doing this , My wife's uncle is helping me in doing a 12'x13' with 9' ceiling. I ordered 10'x12' dry wall {x12} I pick up some dry-wall screws with auto stops a small box of screws a dry-wall "T" Square and knife.
Now for tape is the paper better to use for seams and inside corners? What about mud better to mix or premix ?
Now do I kneed 3 coats of mud and sand between coats?
Need your input pleas , Thank you
bote110 is offline   Reply With Quote
Old 02-16-2013, 12:13 AM   #2
Bumpr1080's Avatar
I haven't had as much experience as many of the other guys here by far- but from my working I strongly recommend mesh tape and pre mixed mud.
For one thing the mesh tape does not require pre-muddying to make it stick and its far easier to use and apply; and more forgiving for novices like us.
I find that the cost is almost equal for pre mixed and dry mud, and the big buckets can be much more easily sealed up and stored for future use. Make sure you get a nice drywall hawk and a concave ~14" knife for the big spreading. Larger your knife, than usually the less sanding you need to do.
I like to use a damp sponge between coats and I sand at the end. I find the sponge softens the ridges and smooths everything out nicely between coats.
Bumpr1080 is offline   Reply With Quote
Old 02-16-2013, 02:14 AM   #3
Rewards Points: 626
Mesh tape yuck! if you use the wrong one you will have a mess on your hands. Best place to get better information is youtube type in drywall Myron Ferguson the Drywall guru.
Nailbags is offline   Reply With Quote
Old 02-16-2013, 02:26 AM   #4
Bumpr1080's Avatar
Well, I'm sticking with mesh. But YouTube is a great place to learn- there's tons of great videos.
Old 02-16-2013, 08:08 AM   #5
Rewards Points: 13,300
If you use mesh you have to have much more build up and a wider joint to blend it in.
Dry wall finishing always takes at least three coats even if your a "pro".
The key is use thin coats, no sanding needed between the first and second coats, just knock off the high spots with the drywall knife.
The green top premixed will work fine.
Work out of a drywall pan not the bucket.
Add a small amount of water for the last coat to thin it for a smoother finish.
Old 02-16-2013, 09:55 AM   #6
Davejss's Avatar
Rewards Points: 740
I use paper tape. Good tools make a difference too. I do my taping with an 8" knife. I use a concave trowel for the second coat, and a flat trowel for the final coat. I use a sanding pole with mesh and I keep a triangle grit sponge with me for small areas. I usually work off a hawk rather than a pan but to each his own.
After sanding I wipe the surfaces down with a damp sponge to get the dust off and to feather any edges I may have missed while sanding. Next I prime. After the primer dries I go over the project with a light held near the wall and mark any imperfections with a pencil and touch-up as needed.
Davejss is offline   Reply With Quote
Old 02-16-2013, 02:38 PM   #7
Rewards Points: 512
1. prefill any gaps that are 1/4" and larger with powdered setting compound (20,45,90)
2.apply paper tape with green lid bucket mud(it has an adhesive and your tape will also suck in)with a 4-6" taping knife
3. apply 2nd coat with a 10"knife using a premixed compound (blue lid, red lid, etc.)
4. apply 3rd coat with same mud as 2nd coat using a 12" knife no thinning is required all comes down to type of mud and personal taste.
5. sand with a sanding sponge and a hand held light shining on your work to see imperfections
for inside corners prefill anything over 1/4"
apply tape with 3-4"taping knife using green lid mud.
coat one side of the corner with a 4-5" knife using a premix the same with what you used on 2nd/3rd coat
when the first side is dry coat the other side
sand the same way with a light.
you can use mesh tape but its more prone to cracking.
apply the tape to the joints
for first coat use a powdered setting compound (20,45,90)
then coat it the same way as i said with second and 3rd coat then sand.
i do not recommend using mesh tape for inside corners.
once everything is sanded i go over the walls with a broom.
in the top corners i take a dry paint brush to dust.
then finally apply your primer
princelake is offline   Reply With Quote
Old 02-16-2013, 03:06 PM   #8
Rewards Points: 660
To jump in and offer a question to the pros: do you always use the paper tape on the inner corners?
What about the outer corners? Do you always use the metalic corner piece, or do you sometimes just use paper tape if it is unlikely to be bumped (soffit edge)?
B
Beepster is offline   Reply With Quote
Old 02-16-2013, 03:16 PM   #9
B
Paper tape for everyting except the outside corners.
Metal corners hold up the best.
Going to be one sloppy mess if you just used tape on an outside corner.
Old 02-16-2013, 04:30 PM   #10
Rewards Points: 512
yup always use paper for inside corners.
metal corners do hold up well.
the best product for outside corners is no-coat ultra flex 325
Old 02-16-2013, 05:59 PM   #11
Use paper tape if the compound container says to. I think you have to use paper for pre-mix. When you're applying the tape, make the compound a little thinner than for the other coats. For corners you can use metal beading that has paper pre-applied.
I never taped drywall but I'm planning to soon so I did research recently.
Dorado is offline   Reply With Quote
Old 02-16-2013, 11:24 PM   #12
Rewards Points: 141
Thanks for all the great info's , My only concern now will be inside corners.
Do you apply a coat of mud on one side then apply the tape fold in half and apply the coat on the other side then the usual 3 coats ?
Should a 10" and a 4" knife be ok to use for my mud?
Old 02-17-2013, 01:59 AM   #13
Rewards Points: 512
there should be no need to thin your mud when bedding the tape. all premixed compounds say you can tape with it but when you go to the cgc website it will say if its excellent or only good for taping. i recommend using only the green lid for bedding the tape because it has the most adhesive in it and its already pretty soupy. i also dont recommend the metal with paper outside corners. i recommend no-coat or good old metal bead.
when doing inside corners coat both sides with mud then fold your tape and push it into the corner and then run your knife down squeezing out the mud(not to much) then coat one side of the corner on the second and on the 3rd coat do the other side of the corner.
you could probably get away with just using a 4" and a 10" knife but you may run into a few issues. bedding the paper tape on your butts and flats will be a pain having to scoop mud apply 2' then scoop again but can be done. i recommend taping with a 6" because you can get 4-5feet with a scoop.
second and third coat you'll have zero issues using a 10" for both.
for inside corners if you bed your tape with a 4" knife you will end up with a ridge at 4inches and when you are coating it with the second coat you can run into problems. so if you bed the tape with a 4 i recommend moving up to a 5-6" for the second or bed the tape with a 3" and coat with a 4"
drywall knifes are cheap. buy a 4,5, and a 6.
oh and inside corners only need to be coated once. all you are really doing is skimming out the thickness of the paper.
Old 02-17-2013, 10:31 PM   #14
Rewards Points: 141
So tape or metal bead for inside corners? The metal bead you screw on with dry-wall screws and apply mud with 3 coats.
I found in Lows some paper tape with sticky on one side any good?
Will a 5gal bucket of the green lid mud be good for 12'x13' with 9' ceiling room ?
Old 02-18-2013, 11:02 AM   #15
Rewards Points: 5,974
I would sure love to see how you are going to get a nice crisp 90 corner with mesh tape. And on inside corners how your not going to cut it with your knife. Since you said 9' ceilings and nothing about 54" drywall I don't know what the 12' sheets are for since you are probably going vertical and not a belly band. Also on a vertical seam mesh tape is very weak so in a couple years if your seams start cracking you will know why. Also mesh tape doesn't work well where the wall meets the ceiling either. That's why paper tape has the crease down the middle that you can't get with mesh.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
Gary in WA (02-18-2013), Nailbags (02-21-2013)
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 08:49 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Wiring an Itermatic Wall Timer in a 4 way stitch SunnyInFlorida Electrical 8 04-28-2011 12:15 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
