New To Drywall Repair - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-01-2013, 12:34 PM   #1
Rewards Points: 160
New to drywall repair
Ok so I made a 10" X 10" hole behind my dishwasher to drill a hole through a stud for wiring an outlet under the sink. I only have access to one stud since the other stud is behind the kitchen cabinets.
What is the proper way to hold the drywall in place when I apply mud to it?
word2yamutha is offline   Reply With Quote
Old 11-01-2013, 04:15 PM   #2
Rewards Points: 13,968
Strips of wood behind the drywall screwed into place through the old drywall.
http://www.bing.com/videos/search?q=...16613A5BC92A7C
Old 11-01-2013, 07:35 PM   #3
Rewards Points: 160
Well what if I cant get to one of the studs? Its right behind a kitchen cabinet.
Old 11-01-2013, 08:28 PM   #4
Got a picture?
There's no need to reach a stud, just use a strip of wood behind the sheetrock that's there now that stick out enough to be able to screw the patch two.
The strip of wood gets screw in place first then the patch.
A 1 X 4, 4" strip or plywood, a 2 X 4 what every you have laying around will work.
Old 11-02-2013, 01:19 PM   #5
Rewards Points: 160
Thanks for the help. Do I need to sand every time I put a coat of mud on after it drys? Also, how many coats of mud should I do?
Drywall repair REXAMUS Drywall & Plaster 7 12-21-2011 03:24 AM
Suggestions to repair drywall around recessed light OhmZoned Drywall & Plaster 10 11-19-2011 06:07 PM
Using tape on a ceiling drywall repair janralix Drywall & Plaster 8 09-22-2011 10:07 AM
Drywall Repair - Paint peeled off down to drywall TJoy Drywall & Plaster 5 06-24-2011 02:48 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
