New Drywall To Old - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-10-2008, 10:16 PM   #1
Rewards Points: 260
New drywall to old
What is the best way to blend it in? The old drywall has a textured finish. It looks like someone just applied finish across the surface with a drywall knife. I know I will have to use joint compound on the seams. Should I sand down the texture/top coat on the old drywall before applying the tape and compound, or is there a way to remove the texture top coat?
bluefitness is offline   Reply With Quote
Old 12-11-2008, 04:36 PM   #2
Rewards Points: 5,336
Old compound(pre1980) contained asbestos particles. You would be better off applying water to the area and scraping off the texture.
Ron
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 04:15 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 08:29 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
