New Drywall Installation, 1 Joint Screws Are Popping - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-15-2008, 11:29 PM   #1
New Drywall Installation, 1 joint screws are popping
I just put 5/8 sheetrock up on the ceiling in a bathroom I am remodling on 24" centers. I am getting close to taping and went back and looked at it after it sat a few weeeks and one side of one joint seems to have buldged out the screws a bit. I have 18" of blown in insulation above it but was very careful not to get any in between the joists and the new drywall. I put extra screws in (almost 4-5" spacing). Anyone have any suggestions on how to fix it? Does the piece need to come down and be replaced or can it be fixed hopefully? The bathroom is 10'x10' but only about 5 feet of one piece seems to have this problem. I added more screws in so have screws about every 2" through this area now. After the new screws were in I could here the sheetrock moving (not cracking per say) but making noise. Any ideas?
zjowens is offline   Reply With Quote
Old 12-15-2008, 11:39 PM   #2
Registered User
Termite's Avatar
Sounds like there might have been some unseen damage to the sheetrock in that area. Probably need to remove it an re-hang a new piece.
24" centers is pretty far apart, so having good solid sheetrock is critical.
Be careful that the screws aren't being overdriven. If they break the paper face of the rock, they're of no value.
Old 12-16-2008, 09:21 AM   #3
thanks
Most of the screws did not break the paper but just buldged out around the screw head. Two other things came to mind. House is in Minnesota and we have recently had -15 degrees F days. I do remember this piece being a very snug fit in this area when I installed it. Could that have something to do with it as well?
I am guessing there is no good repair to the existing piece now?
Old 12-16-2008, 10:23 AM   #4
Registered User
Termite's Avatar
The drywall is bulging around the screw heads? Did you use a drywall dimple bit or just a regular screwdriver bit?
Can you post a picture?
I doubt this is weather related.
Old 12-16-2008, 10:34 AM   #5
just a regular bit. This was actually the most complicated piece I have ever put up. After messing around in the attic for the electrical, the insulation had sagged some so I had to preset almost all of the outside screws on the sheet before driving them all the way in. So I basically slowly brough the sheet up with the screws to prevent snapping the drywall or popping the screws out. Again, when I left it a month ago it all looked good. Now there are noticable bulges around the screws. I will post some pictures tonight...
Old 12-16-2008, 06:02 PM   #6
cocobolo's Avatar
Rewards Points: 6,114
A proper drywall bit would have been helpful, as it releases itself from the screw at the right time and does not overdrive the screw. If your drywall was tight, that may well be the cause of the problem. Next time, you could try to put the screws in pairs, that is to say two screws about 1 1/2" apart on about 8" centers. I expect you have used the water resistant drywall, since this is a bathroom.
I think I might be inclined to remove it and start over, drywall is cheap.
cocobolo is offline   Reply With Quote
Old 12-16-2008, 07:09 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
The bulges are from the paper around the screws giving way, and the sheet is starting to come back down again. You may have to locate the joists on either side of that seam, draw out an area. Then cut the sheet back to the next joist on either side. Replace the area with new sheetrock, and this time use a drywall screw gun, or a drywall attachment on the drill.
Additionally, before you install the new section of sheetrock, check to see if that joist is flush and even with the surrounding joists (use a straight edge). If not, you may have to shim it to align with the others. That would help reduce the chances of the new screws popping thru.
- Build Well -
Old 12-16-2008, 11:07 PM   #8
cocobolo's Avatar
Another thought just came to mind after reading the previous post. Since your joists are on 24" centers, perhaps it would be worth it to strap the ceiling on 16" centers. You could shim the strapping so it was even without too much difficulty. Just a thought.
Old 12-17-2008, 03:48 AM   #9
Wethead's Avatar
Its sounds like your going to have to just replace that board for sure, I men I would,
Wethead is offline   Reply With Quote
Old 12-17-2008, 09:12 AM   #10
Thanks for all the comments. Did not get a chance to post pictures yesterday, will do it tonight. Sounds like the problem is the board is coming down though. With this being a difficult piece to replace with multiple cutouts and the wall board already up, what do you guys think of this solution - Go up in the attic and screw a 2x4 into the existing joist next to the edge that is starting to fail. Drive a new line of screws into the sheetrock 1" farther in from the original line of screws.
Old 12-17-2008, 01:35 PM   #11
cocobolo's Avatar
Well, I guess if replacement is not practical, then sistering the ceiling joist might well be a viable alternative. I think you will have to screw the sister boards on to the existing joists, because if you try to nail them, the movement of the joists when you smack the nails in will only do more damage. One advantage of the sistering which you suggest, is that the new boards can just lay completely flush with the top of your drywall. Can I suggest that you get very straight boards to do the sistering with. That way you will get a nice flat ceiling. It might even pay you to take a few minutes and run some boards through your tablesaw. I expect you know the trick of temporarily tacking a strip of plywood onto a board to get a straight cut? If not, just ask.
Old 12-17-2008, 05:26 PM   #12
Did you glue the drywall before screwing it?
RocketRon is offline   Reply With Quote
Old 12-17-2008, 08:26 PM   #13
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
Carefully take down the suspect sheet of drywall. Then lay it down on a new sheet of drywall and trace out all of the cutouts. Recut. Re-evaluate the framing and insulation. Make adjustments as needed. Install new sheet of drywall.
Sir MixAlot is online now   Reply With Quote
Old 12-18-2008, 09:20 AM   #14
pictures
Here are some pictures. This was a weird joint to begin with. I have 1/2" green board above the tub with extra support and the white board is 5/8". You can see that the green board is fine but the white is where I am haveing the issue. Again, when I put it up, the screws on the white board looked like the ones on the green board. In the third picture you can see the end of each board and the wall face. I forgot to put a straight edge up but it sure looks like that joist may be higher then the rest? That would explain why these screws may be popping since the board is under tension?
New Drywall Installation, 1 joint screws are popping-dsc_0004.jpg   New Drywall Installation, 1 joint screws are popping-dsc_0005.jpg   New Drywall Installation, 1 joint screws are popping-dsc_0006.jpg
Old 12-18-2008, 10:33 AM   #15
Issue # 1: You left this little important detail out in your earlier posts; You are using two different thickness sheetrock and butting them up to each other: Mistake (no-no). They should both be either 1/2" or 5/8".
Issue # 2: It appears that the ceiling joists are not aligned. Picture # 3 shows that clearly. The sheetrock surfaces should not dip up as they do in the pic.
- Build Well -
Tags
bulge , repair , sheetrock
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 04:58 PM
Ceiling drywall cracking and popping sound DoubleM Drywall & Plaster 7 12-17-2008 02:13 PM
screws near drywall butt edges mike_a_davies Drywall & Plaster 2 08-22-2008 07:57 AM
3/8" Drywall Installation Question pjmachine Remodeling 10 02-27-2008 05:07 PM
Drywall screws? Fine or coarse, tip for my drill yummy mummy Building & Construction 31 09-27-2007 02:15 PM
