Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-18-2012, 02:42 PM   #1
Indentured Servant
New to drywall
Are pencil marks a no-no, say to mark a line where a stud is supposed to be? Or another thing I did was write measurements down on the wall. I have not yet applied any mud. or tape.
jackpine is offline   Reply With Quote
Old 12-18-2012, 04:33 PM   #2
New to drywall
you should be able to just work from the top down with the visible stud and or course use the edges of the boards for the other
GreenBoyz is offline   Reply With Quote
Old 12-18-2012, 06:12 PM   #3
New to drywall
pencil marks are fine, ink pen isn't unless you want to seal them all before painting.
The Following User Says Thank You to DannyT For This Useful Post:
sublime2 (12-18-2012)
Old 12-19-2012, 03:18 PM   #4
New to drywall
make sure they are light. You can also erase them before painting
Old 12-26-2012, 01:11 AM   #5
New to drywall
Pencil marks are fine, I will usually mark the field with a pencil using a level, I hate missing studs when screwing off boards. I too will write measurements on the wall.
Assuming you will be mudding and then priming followed by two coats of paint, I do it all the time and it's never been a problem.
chrisBC is offline   Reply With Quote
The Following User Says Thank You to chrisBC For This Useful Post:
oh'mike (12-26-2012)
Old 12-26-2012, 09:49 PM   #6
New to drywall
DO NOT EVER use a permanent marker ! it will bleed through 10 layers of paint, and keep going. ask my how i know.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 12-27-2012, 02:58 AM   #7
New to drywall
Obviously, rollerball pen ink is bad too. I don't remember how it happened, but I ended up with a large ink pen splatter on the face of an unpainted wall, while re-rocking my buddy's bathroom. I suggested sealing it with Gardz or similar, but he ignored me. Two coats of paint later, he went and bought the primer.
Seattle2k is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 06:49 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
