Need Some Repair Help - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 11:25 PM   #1
Need some repair help
I had some foundation cracks fixed and am closing the walls back up and redoing a 12" wall. Everything is going fine except this particular patch is proving a little bother some. The patch is 15"W x 32"T. Part of the patch board is slightly lower on the problem area. When I applied the 2nd coat the top and right side tape bubbled severly after about 15 minutes. I just peeled the tape off and decided to wait foreverything to dry. Any thoughts on how to deal with this? I will have a tape width channel after it dries. I was thinking of reseting the tape with some Durabond after everything dries. Then recoating it to bring it back upeven with everything else.
beerdog is offline   Reply With Quote
Old 04-08-2010, 01:53 PM   #2
Rewards Points: 150
Use mesh tape and setting (hot mud) for the first two coats.
kgphoto is offline   Reply With Quote
Old 04-08-2010, 08:00 PM   #3
Drywall contractor
Rewards Points: 1,070
If you are using paper tape (and ready mix), it needs to dry thoroughly before another coat is applied or "blistering" can occur. Kgphoto's advice is sound if you're trying to speed up the process, and will make for fewer coats to fill the "void" as it doesn't shrink as much.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-08-2010, 09:24 PM   #4
I already made an attemtat fixing it.
1) sponge sanded it back to the starting point
2) leveled the low portion in the middle up to the older drywall edge
3) allowed it to dry
4) sanded so it was a pefectly even joint
5) retaped it.
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
What do you guys think of this roof repair job? darsunt Roofing/Siding 7 08-21-2009 09:43 PM
Fire repair detroitguy66 Building & Construction 3 08-20-2008 06:49 AM
