Need Some Creative Ideas For This Pipe! - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-21-2014, 12:39 PM   #1
Need some creative ideas for this pipe!
Hi all... I'm new here and new to this type of DIY work. I am in the processes of finishing a small room in my basement (half basement, half underground, half above... not sure what they are called).
There is a drain pipe that runs along the cement foundation on the lower half of the wall. Behind it is about 2 inches of framing, polyurethane, and then cement, so i can't hide it inside the wall unless i bring the wall out more. The room is small enough as it is, so I decided not to do this.
Any good ideas on how to hide it? i was thinking of making a vine trunk out of it, or something, or maybe even build some small shelves around it.
Please don't make fun of my drywall job! It's my first time
Furian is offline   Reply With Quote
Old 01-21-2014, 01:29 PM   #2
joed's Avatar
Rewards Points: 11,994
Paint it the same colour as the wall and put some furniture in front of it.
Old 01-21-2014, 02:40 PM   #3
I was thinking htat but it would have be something specifically designed for that purpose... anything too big would block the pathway to the bed. This part of the room is only 97 inches wide. I have a queen size bed going in there (60 inches or so), so there is only 2-3 feet of space there.
Old 01-21-2014, 03:00 PM   #4
Rewards Points: 736
Just box it out, floor to ceiling, it'll just look like a column along the wall that wouldn't stand out in the least.
TheBobmanNH is offline   Reply With Quote
Old 01-21-2014, 03:26 PM   #5
That's a great idea, maybe even a wood column (i have a lot of wood in the home). Thanks!
edit: or better yet, a log column! cant imagine the precise measurements i would need to do that though.
Old 01-21-2014, 06:19 PM   #6
Professional
TotalHomeworx's Avatar
Yeah, I would box it out. Use some steel L-track and drywall to build it so you can keep it small as possible as opposed to wood framing. It will be in the steel stud section at HD or lowes, etc.
Drywall looks life so far just needs to be skimmed out a bit more.
TotalHomeworx is offline   Reply With Quote
Old 01-21-2014, 06:23 PM   #7
Thanks for the tip. I just started taping it up, so i need a few more coats before I'm done. The taping and floating is much more work than I anticipated.
Old 01-21-2014, 06:30 PM   #8
Professional
Yes, it can be. It's easier to keep putting thin coats on. Sanding sucks. Just scrape off the high spots (usually just the lines) and keep coating. Butt joints should be a couple feet wide. Recessed joins are about 16" wide
Old 01-21-2014, 08:57 PM   #9
Davejss's Avatar
Rewards Points: 740
Fire your plumber ;-)
Davejss is offline   Reply With Quote
Old 01-22-2014, 03:28 PM   #10
Rewards Points: 1,442
You don't need to sand between coats. Just scrape off the high spots.In the pic it looks like you've been doing lots of sanding. Wait until after the final coat unless it's something really bad.
mikegp is offline   Reply With Quote
Old 01-25-2014, 08:27 PM   #11
Rewards Points: 512
i'd build a column and stop it at the top of the pipe. get creative and add some shelves for books or nic nacs or something
princelake is offline   Reply With Quote
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
creative plywood ceiling ideas? t_mccann Remodeling 12 02-28-2012 03:16 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
Any creative ideas on how to build some legs/bases for my new glass table? joeyboy Interior Decorating 15 07-07-2007 09:23 PM
