well before i primerd, the mud and tape looked perfect. but after the primer. you can see the outline of the tape. should i just go over it again with some mud??
also. is there a section on here that shows how to post pics??
thanks , jim
The important question would be can you FEEL the tape or is it just visible? Tape is a paintable surface and if the joint is smooth to the touch there's no need for more mud....
take a straight edje and check for flat on the recessed seams you may need to sand some depending on how high. your butts are going to be high thats why I feather to each side at least 12"
well, after the first coat dried for a few days,, the lines from the tape almost totaly dissapeared. i put on another coat of primer. and now there gone.i think the tape might have just sucked up the moisture from the paint..
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
