-   -   need help with tape please (http://www.diychatroom.com/f101/need-help-tape-please-62100/)
fishtale 01-17-2010 12:25 PM
well before i primerd, the mud and tape looked perfect. but after the primer. you can see the outline of the tape. should i just go over it again with some mud??
also. is there a section on here that shows how to post pics??
thanks , jim
Scuba_Dave 01-17-2010 12:36 PM
Is this on the tapered edge joint or a butt joint (non-tapered)
How big of a knife did you use when mudding ?
fishtale 01-17-2010 01:03 PM
both, i think i used a 8"
bjbatlanta 01-17-2010 03:13 PM
The important question would be can you FEEL the tape or is it just visible? Tape is a paintable surface and if the joint is smooth to the touch there's no need for more mud....
fishtale 01-17-2010 03:42 PM
you can feel them a tiny bit. there not raised way up or anything, but you can just see and feel the outline of the tape.
thanks
fishtale 01-17-2010 03:44 PM
and i was going for a smooth look. wasnt gonna texture if i didnt have to
tpolk 01-17-2010 03:47 PM
take a straight edje and check for flat on the recessed seams you may need to sand some depending on how high. your butts are going to be high thats why I feather to each side at least 12"
bjbatlanta 01-17-2010 03:49 PM
Pull a "tight skim coat on either side of the tape and you should be fine.
tpolk 01-17-2010 03:52 PM
:thumbup: and reprime:thumbsup:
fishtale 01-17-2010 04:24 PM
cool. ill let ya know how it turns out:thumbsup:
fishtale 01-28-2010 09:23 PM
well, after the first coat dried for a few days,, the lines from the tape almost totaly dissapeared. i put on another coat of primer. and now there gone.i think the tape might have just sucked up the moisture from the paint..
