Need Help Removing Adhesive - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-16-2010, 07:09 PM   #1
Hello. I just removed some wood paneling from a bedroom and now im left with the adhesive on the walls. The house was built in 1965 so I'm pretty sure the walls are gypsum board with a few light coats of plaster. What is the best way to get rid of the adhesive? Ive pretty much sanded most of it off of one wall with a palm sander and 60 grit paper but it is long and tedious, I didnt know if there was any chemical removers anyone would recommend. Thank You.
SteveBman is offline   Reply With Quote
Old 01-16-2010, 08:44 PM   #2
firehawkmph's Avatar
Rewards Points: 1,822
Steve,
If it's a liquid nails type of construction adhesive, you could try a heat gun or blow dryer to soften it up and scrape it off. Then go around and patch the gouges and defects left by the scraping. If worse comes to worse, you could always go over it with 1/4" drywall.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Removing Granite & Omni Grip Adhesive from Fireplace Surround RayJak Tiling, ceramics, marble 4 11-13-2009 04:28 PM
Removing carpeting adhesive from wood stairs? P550 Flooring 3 10-02-2009 08:33 AM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 09:38 PM
removing adhesive novice40 Flooring 6 07-19-2008 11:31 AM
