Need Help Identifying This Material - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-19-2014, 08:13 PM   #1
Need help identifying this material
Hello all. New to the forum. I was removing some drywall and found this stuff and immediately, fears of asbestos struck. Can anyone tell me if this is safe? I'm going to have it tested, but being the long weekend, I won't know for a few days.
One pic shows the label on the back. It says
"ROCKLATH
The fireproof lath
Made in Canada
Canadian Gypsum Co., Ltd"
Second pic shows side profile. It looks like cement board on top of plaster, and there's some kind of animal hair in the cement.
Any help appreciated. TIA
Need help identifying this material-img_1956.jpg   Need help identifying this material-img_1957.jpg
accws is offline   Reply With Quote
Old 04-19-2014, 08:32 PM   #2
Civil Engineer
Rewards Points: 4,514
Canada is a leading producer of asbestos product. It is certainly possible that there are asbestos fibers in the material, it is IMPOSSIBLE to determine via visual inspection. You are sending a sample to a laboratory, so that will determine if it is asbestos, and if so what type of mineral was used. In the interim, you should treat it as though it is asbestos containing, meaning that during demolition you should use standard asbestos precautions. The U.S. EPA has guidelines for handling asbestos containing material on their web site.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
MTN REMODEL LLC (04-19-2014)
Old 06-22-2016, 06:33 PM   #3
Rewards Points: 36
Re: Need help identifying this material
Bumping this from the dead, I have the same stuff in my house. Would PM but I don't have enough posts!
cjp2003 is offline   Reply With Quote
Old 06-23-2016, 10:14 PM   #4
Rewards Points: 36
Would another forum member like to PM the OP on this post? I'm trying to get my posts up but it's taking a while. TIA. Much appreciated.
Old 06-28-2016, 01:04 PM   #5
Rewards Points: 36
Well I had mine tested. Came back negative. Lots of cellulose fibers in it which looked pretty scary beforehand.
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 03:38 PM
Gap-filling material for r.r. tie sidewalk Hi Country Home Building & Construction 1 05-28-2011 09:58 PM
Water Fall - Black bonding material cprao Landscaping & Lawn Care 3 04-23-2011 04:06 PM
Need some help identifying ceiling material / layers Troglodyte Building & Construction 4 05-22-2010 02:58 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
