Need Help With Framing Closet - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 09:39 PM   #1
need help with framing closet
Ok .. in another thread asking for help with drywall for a closet people suggested I just reframe the closet entirely.
Now I need some help with that.
Here's the before pictures and where it's at now. ARGH ... really dislike when the pics don't go in order .. the first two are before I tore it all apart and with the front dry wall off. The THIRD picture is where it's at right now, not nailed but just leaned up for show. The LAST picture is the closet in the other room and what this one looked like before I started.
I did a quick frame in of the door and just leaned it up to get an idea of space and saw the problem. I'm using the original closet wall on the left side there and really don't want to move that if I don't have to but I have no room for header jacks and all that.
Suggestions?
need help with framing closet-img_0430.jpg   need help with framing closet-img_0434.jpg   need help with framing closet-img_0435.jpg   need help with framing closet-064-copy-.jpg
MzMolly65 is offline   Reply With Quote
Old 06-13-2012, 11:38 PM   #2
Rewards Points: 1,442
Make it shorter? What's your goal? What are you trying to change?
mikegp is offline   Reply With Quote
Old 06-14-2012, 01:23 AM   #3
Goal is to make it more solid and be able to drywall it properly because the way it was, the whole thing wobbled and the front was just a piece of drywall hanging down to cover the tracks but not taped and mudded. When I took off the drywall the whole thing was held together with a couple of nails and some wadded up masking tape for shims.
That's currently as short as I can go for a 36x80 bifold. Looking at it I could shift the opening to the left, pressing it right up against that standing wall, but I don't know if that's going to help much.
Anyone?
edited to add: I just had a face palm moment .. when I cut the rough opening height I cut 82" from the top of the sole plate. That should have been 82" from the floor and I'll gain 1.5" at the header when I correct that.
Old 06-14-2012, 03:50 AM   #4
Rewards Points: 2,210
Don't need a 'header'
Frame like a regular interior wall but a sloped single top plate.
Don't even need double studs or double above door unless you want it for backing for trim.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
MzMolly65 (06-14-2012)
Old 06-14-2012, 08:43 PM   #5
Thank you, I think that helped me come up with a satisfactory solution.
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 03:20 PM
Rough framing for closet door neight Carpentry 9 01-09-2011 07:01 PM
framing closet around a panel polack Electrical 12 01-25-2010 09:04 PM
Framing closet door on top of existing ceramic tile? puddles55 Carpentry 2 01-02-2010 07:50 AM
Framing a Closet & Laminate Flooring Chuck Remodeling 5 01-03-2007 12:35 AM
