Need Help Fast! Drywall Understairs - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-05-2014, 01:31 PM   #1
Need help fast! Drywall understairs
Hello fellow member from UK here
I put my foot through a portion of ceiling so took it down and whilst I had the oppturunity run some cat6 cables.
Thing is now im stuck on what to do here and the best way to frame out in order to accommodate more cables. I need to lower the ceiling slightly enough for the cable run.
What best to frame out ready for plasterboard/sheetrock?
any tips or diagrams will be helpful.
Many thanks
10crazyfists is offline   Reply With Quote
Old 02-05-2014, 01:32 PM   #2
Old 02-06-2014, 01:27 AM   #3
Please guys help me out here :D
Old 02-06-2014, 02:26 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
You could just frame out with 2X4s, on the same angle as the stairs, past all the wires and install sheet rock, shouldn't be too hard to do.
It is pretty late at night here right now, I am sure some of the other guys will have other suggestions tomorrow.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-06-2014, 05:58 AM   #5
Rewards Points: 12,794
That's the way I would do it.
Pad it out with 2 X 4's laying flat against the studs on that knee wall under the stairs, then add three more to set up against the bottoms of the stair treads and attached at the top and bottom.
Old 02-06-2014, 08:40 AM   #6
joed's Avatar
Rewards Points: 11,516
Instead of framing to the bottom of the steps do it in one piece and frame to the top of the little bump out from the top of the steps.
Old 02-06-2014, 11:53 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Attachment 80800
This is the way I had in mind also.
How do you make the red lines like that?
Jim
Old 02-06-2014, 01:07 PM   #8
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 846
If you're running a windows machine, you can do it with the "Snipping tool".
Sir MixAlot is offline   Reply With Quote
The Following User Says Thank You to Sir MixAlot For This Useful Post:
BigJim (02-06-2014)
Old 02-06-2014, 01:07 PM   #9
Thank you guys I knew I would get some helpful advice.
My next question is how should I fix the new timber? Don't want to think it may fall on someone If I don't fix it well.
Old 02-06-2014, 01:36 PM   #10
joed's Avatar
Use MSPaint.
I think I would use screws to fasten it. Less chance of doing more damage to the existing plaster from hammering in nails.
I also just realized that picture is sideways. here is right side up version.
The Following User Says Thank You to joed For This Useful Post:
BigJim (02-06-2014)
Old 02-06-2014, 01:46 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Thanks Joe, I will give it a try.
I thought something was wrong with that picture.
Jim
Old 02-06-2014, 01:51 PM   #12
Thanks fellas
I will go get some 2x4 timber on the weekend and attempt to put it right as my wife is nagging me that it looks awful :D
Will post my progress.
Thank You all
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 10:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
