Need Help Creating Texture - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-10-2010, 08:35 PM   #1
I have been asked to do a texture I have not done before, it looks like it was created with a jagged trowel and the pattern overlaps. I have heard it referred to as Sea Shell. If anyone could explain how to recreate this texture I would be very thankful.
oldglory1 is offline   Reply With Quote
Old 04-11-2010, 03:07 PM   #2
Rewards Points: 5,336
Impossible to tell you how to do something we haven't seen. Post some photos.
Ron
Old 05-18-2010, 12:15 PM   #3
I've seen this texture before, I used to have a house with this on all the ceilings. I believe it's called a "mud swirl texture".
Are you trying to patch an area with this texture and make it match the areas around the patch?
Or are you trying to match the texture in a new, separate area to that of somewhere else in the building?
This is actually one of the easiest textures to reproduce. Get some textured compound paint from home depot and apply it to the ceiling with a paint roller. Let it sit for 10 minutes and take a stiff-bristled brush or broom and make a pattern on it.
You can practice on a scrap piece of drywall to develop a technique to better match the existing patterns.
Hope that helps!
Homer
homerb is offline   Reply With Quote
Tags
drywall , finishing , texture
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 09:00 AM
How long should I wait to paint texture? bluefitness Painting 1 12-11-2008 12:51 PM
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 07:24 AM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 05:09 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
