Need Help With Ceiling Texture - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 01:39 PM   #1
Exclamation
Need help with ceiling texture
Does anyone know what was used to get this texture on ceiling?
http://tinypic.com/r/2621u8k/5
Jimmy
sparkymc is offline   Reply With Quote
Old 12-01-2011, 02:05 PM   #2
Rewards Points: 13,712
http://www.drywallschool.com/textures.htm
If the plan is to try and match this to do a repair, most likly it's not going to happen. You'll find it's nearly impossable to get an exact match.
Most often the whole ceiling will need to be redone to get it all even.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
logluvr (12-06-2011), sparkymc (12-01-2011)
Old 12-01-2011, 02:17 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That was done with a crows-foot applicator is my guess. You also must consider the viscosity of the compound at the time of the application along with the quantity of compound deposited on the surface before tooling.
I wouldn't get my heart set on matching that in a patch if that's what you are doing. How about some more details on what you are doing and another picture that isn't a close-up?
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Old 12-01-2011, 04:30 PM   #4
Here are some more pics. Yes, I patched a hole in ceiling from water damage. Just need to texture it but cant find a good match.
http://i1236.photobucket.com/albums/...n/ceiling5.jpg
http://i1236.photobucket.com/albums/...n/ceiling4.jpg
http://i1236.photobucket.com/albums/...n/ceiling3.jpg
http://i1236.photobucket.com/albums/...n/ceiling2.jpg
http://i1236.photobucket.com/albums/...n/ceiling1.jpg
Thanks!
Old 12-01-2011, 04:33 PM   #5
And as any real sheetrocker will tell you your not likly to.
Redo the whole ceiling and it will match.
Old 12-01-2011, 04:44 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You are wasting your time trying to patch it. If it has never been painted you can mist the entire ceiling with water using a garden sprayer, wait a few minutes and then go to scraping the entire ceiling. It will come off easily. Once dried lightly sand it, and start over.
The pictures don't show us anything. A much larger field of view would be more helpful.
XXX
Old 12-01-2011, 09:19 PM   #7
House was built in early 70's. Ceiling is painted.
Jimmy
Old 12-02-2011, 10:33 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'm sorry.
XXX
Old 12-02-2011, 12:29 PM   #9
It looks like a slap brush texture. Just fyi, those textures are commonly asbestos containing.
mbryan is offline   Reply With Quote
Old 12-06-2011, 03:18 PM   #10
Drywall contractor
Rewards Points: 1,070
It's a "stipple" texture. Mud is thinned to allow it to be rolled on the ceiling. A "shag" stipple brush (available at All-Wall.com, under "texture brushes") is then used to make the texture. It is hard to blend a patch if you're not experienced. I would recommend having a pro do the repair.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
ceiling , match , texture
Ceiling texture ideas? DangerMouse Drywall & Plaster 11 04-26-2011 08:03 PM
Need help with blending new texture ceiling catzcar Drywall & Plaster 9 04-11-2011 09:00 PM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
Removed popcorn ceiling, now how to texture? mikereno1 Remodeling 7 02-23-2009 07:05 PM
Ceiling Texture Matching MJBhoya Painting 3 02-08-2009 10:04 PM
