-   -   Need guidance on drywall repair (http://www.diychatroom.com/f101/need-guidance-drywall-repair-145794/)
Theresa_la68 06-02-2012 11:49 PM
I hired a mature handyman to remove a stubborn wall border. Unfortunately his tool stripped the drywall to the core of the drywall. Using Pirana's wallpaper removal gel I was still unable to remove the border. I need to fix these walls tomorrow. Help and thanks! T
oh'mike 06-03-2012 06:12 AM
Prime the area to be repaired--wet mud will lift the damaged paper causing bubbles.
Guards or 123 would be a good choice.
Use Multi Purpose (green lid) joint compound or Easy Sand powdered mix---either will bond well--
Thin coats---Mike---
joecaption 06-03-2012 08:12 AM
And it's going to take about 3 days at least for this job.
Use a wide knife when applying the dry wall compound.
Apply thin coats like Mike suggested, let it dry, wipe the knife over the surface to knock off the high spots and apply another coat, let dry then a light sanding in a ciruler motion, if there's any low spots of air holes apply another coat.
Paint will not fix the flaws!
The repair will need to be primed before painting.
Theresa_la68 06-03-2012 08:53 AM
Thank you
Thanks for your help -- I was hoping there was an 'insider' secret
:). I'll do it right over a couple days. T
oh'mike 06-03-2012 09:01 AM
The time depends on your taping skills---Usually 2 coats needed--use the bag mix and it will be ready to sand in a couple of hours---set times--20-45--90 minutes
Fix'n it 06-03-2012 09:40 AM
i removed a boarder in a room once. it didn't much damage the drywall. but boy, what a PITA it was.
the trick is to get it wet, and keep it wet, for hours.
Theresa_la68 06-03-2012 09:46 AM
I was able to remove wallpaper from 2 rooms, but this border is something else. They used a sticky glue that is really stretchy. I'm considering renting the wallpaper removal machine from Lowes. Did u consider or try the machine?
Fix'n it 06-03-2012 10:43 AM
is that a steam machine ? i never used one. but hot water can remove a lot of things.
Theresa_la68 06-03-2012 10:54 AM
Yes. My brother in law recommended a steam machine that I can rent ... I'm almost thinking of putting a border up and call it the day.... :)
