Need Advice On How To Tape Around Window Ledges - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 02:05 PM   #1
Need advice on how to tape around window ledges
I am currently re-modeling a home. I am a carpenter by trade, but now I am to the drywall finishing. I have never drywalled an entire house and am having trouble taping the window ledges around the window (inside and outside corners)..... anyone with advice would be greatly appreciated.
maxjsl37 is offline   Reply With Quote
Old 08-31-2010, 02:52 PM   #2
Rewards Points: 79
windows recessed?
Sounds like you're doing drywall around windows that are set back in the wall a bit. Picture would help. Anyhow - if this is the case, you're using Outside corner bead at the perimiter and as far as taping and applying any compound near the window - You'll be taping the inside corners prior to putting on the outside corners - then where drywall - with skim coat - meets window, figure on a small strip of trim - it looks better and will negate the need for caulking . Caulking is an inevitability when drywall butts a window. If not when you do it - a few seasons later at best. Hope this helped - like i said - a picture or two would help.
jackofmany is offline   Reply With Quote
The Following User Says Thank You to jackofmany For This Useful Post:
maxjsl37 (08-31-2010)
Removing a window for painting... JJDoherty General DIY Discussions 6 08-31-2010 08:39 PM
Brass window hardware? Cleaning/painting advice please JakeS General DIY Discussions 4 06-18-2010 06:48 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 09:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 09:31 AM
