-   -   Need advice on how to tape around window ledges (http://www.diychatroom.com/f101/need-advice-how-tape-around-window-ledges-80157/)
maxjsl37 08-31-2010 02:05 PM
I am currently re-modeling a home. I am a carpenter by trade, but now I am to the drywall finishing. I have never drywalled an entire house and am having trouble taping the window ledges around the window (inside and outside corners)..... anyone with advice would be greatly appreciated.
jackofmany 08-31-2010 02:52 PM
windows recessed?
Sounds like you're doing drywall around windows that are set back in the wall a bit. Picture would help. Anyhow - if this is the case, you're using Outside corner bead at the perimiter and as far as taping and applying any compound near the window - You'll be taping the inside corners prior to putting on the outside corners - then where drywall - with skim coat - meets window, figure on a small strip of trim - it looks better and will negate the need for caulking . Caulking is an inevitability when drywall butts a window. If not when you do it - a few seasons later at best. Hope this helped - like i said - a picture or two would help.
