-   -   Need advice on drywall repair before I paint (http://www.diychatroom.com/f101/need-advice-drywall-repair-before-i-paint-185924/)
word2yamutha 08-25-2013 05:43 PM
1 Attachment(s)
Took out an old home security system that left a couple of holes behind. I have never repaired drywall before if you couldnt tell. I used the prof. spackle with mesh drywall tape. I'm I suppose to paint primer over it first before I use paint? Also, is the mesh suppose to be visible like this or did I sand it too much? Thanks
joecaption 08-25-2013 06:21 PM
Big mistake using mesh tape, should have used paper.
You've sanded way to much off, and used to narrow a drywall knife to apply the mud.
Should have been about an 8" or wider thin coat with an wider knife.
The screws only needed drywall compound not tape.
oh'mike 08-25-2013 06:23 PM
You aren't done yet---why is there mesh over the screws? that is not needed---
Did you use drywall mud or the spackeling compound in the little tub?
That needs another thin coat of drywall mud---wider this time---incorporate the screws and the larger patch---use your 10 or 12" blade.
joecaption 08-25-2013 06:29 PM
If you can still feel a flaw then a it needs more work,
It often takes at least three thin coats.
Should not be using spackle,
Yes it will need to be primed before painting two coats.
user1007 08-25-2013 07:02 PM
Agree with all comments, and know you should not see the mesh with a finished patch. As suggested, you need a nice wide mud knife to even things out---you are not using one wide enough for you next passes. It looks like you will be fine with a coat or two more of....
I wish there were a way to standardize what people mean when they say spackle. I think of it is the overpriced, foamy stuff that comes in tiny containers for an outrageous amount of money. Others have corrected me with assurances some of the new vinyl spackling is nice for larger repairs. I used either drywall mud or actual plaster repair material.
Anyhow, once done with whatever you are using, you will need to spot prime and then paint.
I assume this security system was in a closet? Do not go too anal rentitive on this repair and save it for the next in the middle of the room? Not saying you should not make it as nice as you can. And a closet is a great place to learn this.
ToolSeeker 08-25-2013 07:20 PM
Have no idea what prof. spackle is but for your topcoat at the box stores you can get a small tub of green lid DRYWALL COMPOUND this should be enough for this small patch.
hboogz 08-26-2013 12:42 PM
Just curious, why would you choose green over blue lid for your finish/top coat?
I'm not a pro, but between forums and being on the field I've seen/read so many combos used.
The latest I've seen was when using mesh tape on joints and tape on ceilings/corners, since the green lid has glue, your first coat use the green lid mixed with some water straight from the bucket, then the next two coats use either hot mud or a mix of green with plaster (red or green bag) I've seen this used a few times and haven't seen any cracks, yet.
word2yamutha 08-26-2013 04:24 PM
1 Attachment(s)
Haha Im glad I didn't go through with painting and trusted my gut feelings. Whats the difference between drywall mud and the spackle compound?
When would one use the mesh tape compared to the paper tape for drywall?
Well the main security unit was located in the closet but the hole is much bigger.
The picture is the stuff I have been using.
ToolSeeker 08-26-2013 06:07 PM
Spackle is for small repairs like nail holes and small dents. It has a reputation of shrinking when using for bigger repairs. Drywall mud is made for almost anything from constructing new wall to repairing old ones.
The best time to use mesh tape is absolutely, positively, under no circumstances should mesh tape ever be used. It should be illegal to even sell that crap.
You need to use joint compound I can almost guarantee that stuff will crack.
ToolSeeker 08-26-2013 06:10 PM
In this instance the green because it is a small area and the green lid is all I have seen in the little tubs. A 5 gallon bucket would be overkill.
oh'mike 08-26-2013 06:23 PM
Green lid is just fine for your patch---
Green is multipurpose---it sticks well and is ideal to embed paper---or in your case,mesh---
It is a bit harder to sand than the Blue lid--light weight---bot not all that bad--
Because you used spackle to embed the mesh--I think you are fine--just top coat what you have with a 10 or 12 inch knife.
jeffnc 08-26-2013 10:42 PM
Rather than putting tape over your screws, countersink your screws slightly into the drywall, then cover with compound.
word2yamutha 08-27-2013 12:31 AM
I took the screws out already. I watched a youtube video for drywall repair and they recommend meshtape for added strength. I think Im going to remove the spackle and the mesh and just start over. Thanks for the advice guys.
chrisn 08-27-2013 01:26 AM
you need to stop that:yes:
word2yamutha 08-27-2013 03:51 AM
Lol I guess I learned the hard way, but at least I would rather take the time to do it right.
