Need advice cutting 10" speaker holes
Yes they will Crackers. The speakers should have been located after the lighting cans were located by the electrician. There is no way that this will look good, or look professionally done, once finished.
If I was the OP, I would actually locate the speakers farther away from the lights, depending on how much wire they have up there for them.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
