#1 |
Need advice cutting 10" speaker holes
Hi everyone
I'm not experienced with drywall. I've done some square hole cutting in vertical walls for boxes, but never done circle holes in ceilings. I'm an engineer with good experience with wood and metal, but again not much drywall. So I have about about 28 10" diameter holes to cut into my 5/8" drywall already hung ceilings. The spots have been marked with something called EZ plugs (I may not have the name right). After doing some tool searches I find many don't do a diameter this large and some that do seem to only work if you have access to both sides. I only have access to the outside face. I need a recommendation on what tool to buy and how best to use it. If possible I'd like to minimize the dust during cutting. I've seen people recommend to use scoring type tools, follow it with a utility knife to get a deeper cut, score an big X in the middle, and punch it through. Thanks in advance. |
#2 |
Average Joe/ex-Navy IC3
The speakers should come with a template. You just need to get the hole big enough for the speaker to fit into, and then the grill will cover it. If you are good with a drywall saw, or even a rotozip, it can be done.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#3 |
Keyhole saw.
#4 |
I agree with a jab saw.If you have never used a router (rotozip) you can make swiss cheese out of the drywall it takes a little practice to use one.
#5 |
Even a Jig will work.
If you want to cut down on the dust better have some standing next to with a shop vac with a drywall bag over the filter. |
| The Following User Says Thank You to joecaption For This Useful Post: | princelake (01-07-2013) |
#6 |
Just get a cheap drywall/jab saw (for example: http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053). Since you say you've cut rectangular openigns for wall boxes, maybe you have one already.
Since the speaker baffle is going to be your clean edge, you don't need to cut a perfect hole. Take your template and put in on the ceiling, trace it or stick it up there (depending on the way it is designed) and then use the drywall saw to cut the hole. You can get started by jabbing the saw through the drywall, or you could use a spade bit to drill a starting hole (make sure you drill inside the drywall circle to be removed). Since you don't need a perfect circle and since the saw blade isn't too thick, you will be able to cut a circle with this blade if you twist the blade while cutting. Scoring and then punching out the middle sounds a bit risky - if you mess up then you have a brand-new ceiling that you've just made a mess of. Just use the hand saw and take it slow. I've done this for 6-inch speakers and it was easy (the "hard" part is awkwardly working over your head). 10-inch will be that much easier since the curve isn't as tight. 28 speakers is a lot - doing a whole-home audio system? Last edited by JKeefe; 01-07-2013 at 10:37 AM. |
#7 |
For cutting 28 holes 10" dia. I'd be reaching for my Saber saw with the circle cutting attachment. That would right after I located all electric wires in the area. And there might even be a little duct tape involved with that shop vac hose.
#8 |
you also can get one of these
| The Following User Says Thank You to epson For This Useful Post: | oh'mike (01-07-2013) |
#9 |
STAFF
And be sure to check that you aren't cutting your hole center of a ceiling joist it isn't fun trying to patch a ceiling and make it look right.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
#10 |
Need advice cutting 10" speaker holes |
#11 |
Super Moderator
Just to make sure that there is nothing above that will cause you trouble---take a length of stiff wire--bend it into an L shape (Half the length of the hole 5"?)
Poke a hole in the center of your proposed location---insert the bent end into the pilot hole--- Rotate the wire and slowly raise it,while spinning the wire---if you are to close to a joist or other obstruction--you will hit it---
New members: Adding your location to your profile helps in many ways.--M-- |
| The Following User Says Thank You to oh'mike For This Useful Post: | BigJim (01-07-2013) |
#12 |
Hopefully the OP has selected loudspeaker locations that are clear of ceiling joists. If not, that speaks to an entirely separate issue...
#13 |
Wow, lots of replies. Thanks guys.
A few points... I know the area above all these cutout areas are clear. The EZ plugs were installed by a professional and I took pictures of everything before the drywall went up. However I'm a little concerned these plugs could get in my way if a sawing blade has to cut them too. Enclosed is a picture of one. The round hole is the center point. I do have a very nice drywall hand saw/knife (not correct term). It worked very well on my square holes. I just assumed there were some reasonably priced tools on the market that make the job easier and faster. It seems like the type of tools recommended by Epson work best on the paper side, not the side facing me. Correct? Good advice on the drywall bag for my shop vac. I did not know such a thing existed. |
#14 |
Do not understand the fancy gizmo. Seems like 28 of those would make an awful wavy ceiling. And if your circle goes that close to the can light there won't be room for the beauty rings. Maybe I'm not looking at it right.
#15 |
You are seeing it the same that I am. Total pooch screw on this, with poor planning of the location of speakers & lighting. As for the saw or rotozip, that plastic is going to be nothing to either one.
| Display Modes | |
| Cutting holes for can lights in sheetrock | j_sun | Drywall & Plaster | 6 | 09-23-2012 08:47 AM |
| VCT Trick Design: Cutting and Install Advice Please | steveroberts | Flooring | 0 | 08-15-2012 09:38 AM |
| Drywall ceiling: Water Damage, looking for advice | dawho1 | Building & Construction | 11 | 09-13-2010 11:05 AM |
| cutting 4" holes in 10" floor joist | red_cabby | Building & Construction | 19 | 06-22-2010 05:25 PM |
| Bad Concrete in Fence Post Holes - Advice? | bcrenshaw | Building & Construction | 2 | 08-24-2008 12:21 PM |
