Neat Way For 1 Man To Drywall Ceiling. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-22-2013, 12:37 AM   #1
Rewards Points: 2,210
Neat way for 1 man to drywall ceiling.
Neat idea for 1 man drywalling ceiling.
I would add a staggered 2x4 by 48" at the edge (or on wall) to act as a lip to catch that edge of the sheet.
May still be hard with 12' sheets.
I have thought of a 2x4 mounted to the wall say 32" long. hinged to this would be 2 2x4's say 12' minus the 1.5" for the wall 2x4. Then a 2x4 on the end to also act as a lip to hold the sheet on.
Would work for the full 12' sheets. I guess shorter sheets could be put on and held in place with some screws put in to act as stoppers.
mae-ling is offline   Reply With Quote
Old 08-22-2013, 02:04 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 190
Way back when I was young and didn't have helpers I hung rock on the ceiling alone, it is kinda hard but doable. I screwed 3 pieces of 1X4 to the joist through the last sheet of sheet rock so the next sheet would have something to hold it up on that edge.
I had two pieces of 1X4 with screws into joists turned side ways. Lift the rock onto the three 1X4s, hold the other edge up tight to joists and turn the other two to hold the other side. It was no problem to move the rock around in the right position, then secure. I can't even pick up a sheet of sheet rock now days.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (08-22-2013)
Old 08-22-2013, 09:37 AM   #3
Rewards Points: 13,300
Rent or borrow a drywall lift and eliminate all that work.
Turns it into a one handed job with nothing to have to waste time building and attaching.
ToolSeeker (08-22-2013)
Old 08-22-2013, 09:52 AM   #4
bbo
exactly, I got one delivered from amazon for < 150.
not done using it yet, have a few small areas to do, expect to be able to sell on CL for 100 when I dont need it anymore.
bbo is offline   Reply With Quote
Old 08-22-2013, 09:56 AM   #5
Drywall lifts are great.
For some of us there are not rental places in easy access. I have lived places where the nearest one was about an hour away.
Old 08-22-2013, 10:20 AM   #6
I just rent out the one I bought because I just know if I sell it I'm going to need it the next day.
I've made all the money back it cost me to buy it and still have it.
Old 08-22-2013, 10:38 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
Me too. But I plan on wearing mine out.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 08-22-2013, 01:18 PM   #8
bbo
that might be an even better option. I should offer to family and friends to rent my stuff for a small small fee. saves them the hassle of getting and maintaining tools and allows me to fund more tool purchases.
of course I'm willing to let lost tools or broken tools go, just no more rentals unless they offer to replace. lending tools is like lending money to family and friends. be prepared to just let it go.
Old 08-23-2013, 01:53 AM   #9
Rewards Points: 626
Dry wall lift way easier then what you discribed.
Nailbags is offline   Reply With Quote
Old 08-23-2013, 07:33 AM   #10
DIY staff
Rewards Points: 7,174
Lifts are handy,but it sure is nice to know the techniques to make do without one.
Good craftsmen should know alternate methods----a trip to the rental shop might take longer than the job will take using props and ledgers----
Old 08-23-2013, 08:42 AM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 190
Back when I was hanging rock alone the lift hadn't been invented yet, it has only been on the market for 35-38 years.
Jim
oh'mike (08-23-2013)
Old 08-23-2013, 11:51 AM   #12
Yep drywall lifts are great, make the job easy.
But like I said there is not always one around when you need it. The rental place is 1 hour away or they are all out.
So here is another way to get the job done.
The Following User Says Thank You to mae-ling For This Useful Post:
Old 08-23-2013, 12:16 PM   #13
Rewards Points: 1,442
I've also used my lift for putting up soffit sections. Put up a 14ftx16in made of 2x4's easily by myself.
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
Old 08-23-2013, 11:46 PM   #14
Rewards Points: 940
Have you considered just plastering the ceiling? My dad and I built the house where I was born, and plastered the ceilings.
cleveman is offline   Reply With Quote
Old 08-24-2013, 12:22 AM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 452
When I need to put board on a lid- I hire it out. After observing sheet rockers for a while, I've decided that drywall dust must kill brain cells.
The Following User Says Thank You to TheEplumber For This Useful Post:
ddawg16 (08-24-2013)
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Installing Drywall Ceiling daytrepper Drywall & Plaster 10 02-10-2011 01:52 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
