Narrow Strips Of Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-22-2013, 08:17 AM   #1
Rewards Points: 150
Narrow strips of drywall
Where you have a surface with a 1-1/2" offset... Would you cut the 1" strip of drywall to fit the side edge of the offset?
Note the outside corner bead will overlap the inside corner tape... or even use a metal inside corner bead, seat that, then put the outside corner bead over that?
If you would do the strips, has anyone ripped them on a table saw? With the diamond blades you'd use for cutting concrete board siding of course, not a toothed blade.
Thanks!
SquishyBall is offline   Reply With Quote
Old 08-22-2013, 08:35 AM   #2
Rewards Points: 13,256
Got a picture of what your trying to cover?
Never use a table saw! The gypsum dust will shorten the life of the motor.
Stick with a utility knife, for that narrow a cut I'd be supporting the drywall laying flat on saw horse's with 2 X 4's laying flat on top of them.
When trying to do any narrow inside or outside corner I try to plan it out so the narrow cut is as wide as possible first then do the wider section second.
ToolSeeker (08-22-2013)
Old 08-22-2013, 10:10 AM   #3
Rewards Points: 2,210
For narrow rips I use a plastic speed square. Put the knife on the desired measurement and run it along.
Generally I would put the drywall on the front surface first, making it now 2", then the strip then the drywall on the back surface.
mae-ling is online now   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
joecaption (08-22-2013)
Old 08-22-2013, 10:16 AM   #4
I just happen to own one of these so that's what I use.
http://malcoproducts.com/product/roo...ls-vinyl/sider
Just using your hand to guide it along the edge works ok.
Old 08-22-2013, 11:01 AM   #5
Rewards Points: 150
Alright here's a pic.
Would you do A or B? i.e. do you need the little strip at all if the corner beads will overlap and bond to each other anyways?
Old 08-22-2013, 11:06 AM   #6
Rewards Points: 150
Originally Posted by joecaption View Post
The Sider device is kinda neat... I'll get one of those! I could also just make a fixed width jig out of a couple pcs of scrap plywood.
Old 08-22-2013, 12:35 PM   #7
"You can do anything"-Mom
brockmiera's Avatar
Im no drywall expert but I'd be inclined to do A but without that small piece of drywall. I'd just put the corner bead, tape the corner, and float the 1" section.
brockmiera is offline   Reply With Quote
Old 08-23-2013, 01:06 AM   #8
That slider is neat, would be great for siding!!!!!
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 11:35 PM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 04:13 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 01:24 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
