Nail Pops On Very Old Sheetrock - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-17-2012, 05:39 PM   #1
Nail pops on very old sheetrock
Hi everyone,
My house was built in the 1940's time frame. I have no idea when the sheetrock was installed. It is in pretty good shape, except for the occasional nail pop. I understand what to do for nail pops in sheetrock that is relatively new. Somewhere, at some time, I recall reading that trying to put a new nail or screw in to old, old, old sheetrock wouldn't work .... something to do with the paper being too brittle.
Any comments?
Thanks.
george5558 is offline   Reply With Quote
Old 09-17-2012, 06:43 PM   #2
Randy in Kenyon
My house was built in 1917, but sheet rocked in some rooms in the 40s. Most of the nails were not ring-shanked. Those that popped, I dug out and mudded over the hole and a few inches away, I put in a screw. Of course all this means that you will be mudding and painting..
Regards - Randy
Big-Foot is offline   Reply With Quote
Old 09-17-2012, 06:50 PM   #3
When you put in the screws on that very old sheetrock, did it hold? What I recall reading or hearing somewhere, was that they would pop right through the old brittle paper and not hold at all.
Old 09-17-2012, 07:26 PM   #4
Rewards Points: 13,732
Never heard of that, and I've been working on older homes for over 30 years.
Sometimes you have to push up on the sheetrock as your screwing because the drywall is now sagging.
Add more screws closer together to spread out the load.
Old 09-17-2012, 08:26 PM   #5
Randy in Kenyon
I did not have any trouble with the screws in the old drywall.
For what its worth - When I put up fresh drywall, I screw in every running 12" on walls and every 8" on ceilings.
Regards - Randy
-edit
What have you got to lose? If it pulls through the paper, you still have a screw embedded in the wall and it will hold a goodly load..
Tags
nail pops
Strange bumps (not nail pops) on ceiling drywall davidarlington1 Drywall & Plaster 4 05-29-2012 04:43 PM
Sheetrock in ceiling pops with temperature change john_2011 Drywall & Plaster 1 04-16-2011 02:52 PM
Using nail Gun on sheetrock jwshome Building & Construction 12 09-08-2009 09:16 PM
Drywall nail pops repair? ProudMarineDad Drywall & Plaster 1 06-23-2009 08:17 AM
nail pops nat Carpentry 3 11-11-2006 12:48 PM
