Nail Head Pushing Through My Ceiling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-14-2011, 10:09 PM   #1
Question
Nail head pushing through my ceiling?
Today I noticed what looked like a little blister of paint on my bathroom ceiling. I wanted to make sure it wasn't water damage. I pressed on the ceiling around it and it didn't feel soft or anything, but the head of a nail pushed through the drywall (see attached photo).
Is this a bad sign? How do I fix this?
Thanks guys!
thinksincode is offline   Reply With Quote
Old 12-14-2011, 10:49 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Put another nail right next to that one, the heads overlapping, and gently drive them in together, leaving a little cup that you can spackle over and touch up with paint.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
Bud Cline (12-14-2011)
Old 12-14-2011, 11:07 PM   #3
what titanoman said, or a drywall screw - that way you know it won't back out again.
bethomas is offline   Reply With Quote
Old 12-15-2011, 10:13 PM   #4
sparks1032's Avatar
To take it one step further I have had better luck with laminating screws one in the old nail hole and two more, one on each side. Make sure to use a quick setting (called durabond) filler and prime and paint it when done.
Laminating screws are size 10 by 1-1/4 that are extra course threads.
sparks1032 is offline   Reply With Quote
Old 12-15-2011, 11:16 PM   #5
Rewards Points: 1,092
I'm w/ sparks. Pull the nails, replace in or next to the original hole. Then, get ready to go around a large, large area doing more of the same. I've done this twice, at 20 and 25 yrs. Damn nails.
Old 12-15-2011, 11:20 PM   #6
Disabled wood vet
titanoman's Avatar
Twice? In 25 years?
Old 12-15-2011, 11:30 PM   #7
What actually causes it?
Old 12-15-2011, 11:39 PM   #8
Disabled wood vet
titanoman's Avatar
Vibrations.
Old 12-16-2011, 01:32 AM   #9
(1) Yes, twice in 25 yrs. Two different places. Is that good or bad? (2) Causes: movement of the wood via shrinkage, truss uplift, seismic activity; too much moisture in the house getting the nail heads wet and rusting them, damaging the sheet rock mud and loosening??? ..... maybe others???
Old 12-16-2011, 01:58 AM   #10
Disabled wood vet
titanoman's Avatar
Never mind. I'm not here to hurt peoples feelings or to brag on my experience.
Old 12-16-2011, 02:14 AM   #11
WTH? I think some wires got crossed.
Old 12-16-2011, 02:19 AM   #12
Disabled wood vet
titanoman's Avatar
Maybe you're right. Maybe I'm interpretating your statement wrong.
Are you saying that you have fixed a total of 2 nail pops in 25 years? That's not enough experience to be giving any advice, don't you think?
Old 12-16-2011, 02:28 AM   #13
I wish. Two AREAS, and several little glitches here and there, PLUS I've helped several people patch loose nails. Besides, popped nails aren't exactly a high tech deal, right? One of my problems, btw, was because the "pro" carpenters I had to hire made a pretty wavy wall, and the sheet rock was under a lot of stress. I was surprised that that area lasted the 20 yrs. Once I started screwing the sheet rock down, more and more nails popped as I was able to bend the sheet rock a tad w/ the screws. Had the wall been flat, I am sure the problem would have been much smaller.
Old 12-16-2011, 02:31 AM   #14
Vibrations.
"Good Vibrations"? (Beach Boys. Maybe before your time....)
Old 12-16-2011, 02:31 AM   #15
Disabled wood vet
titanoman's Avatar
Okay.
You're right. Not too complicated.
Ceiling issue wooten General DIY Discussions 5 06-06-2011 08:20 PM
Creating a vaulted ceiling for patio tcaesar1 Building & Construction 1 04-26-2011 11:30 PM
replacing ceiling mount shower head JoanneW Plumbing 3 05-31-2010 09:19 PM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 07:39 PM
