Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-25-2008, 02:02 PM   #1
l1r
My Drywall dilema
Ok, so I've got ugly popcorn texture on my ceiling, and ugly strange knockdown on walls. Walls - I can live with, but ceiling - no-no. So I started off yesterday wetting it and scraping off with old-fashioned floor-scraper (16" handle and a 4 inch blade). PITA, but works (although it will take me until Christmas of 2010 to finish my entire house).
Question 1: Can I use a small orbital sander to sand off WALL texture? I will do ceiling manually, but walls - I'd rather sand them off with a sander or something.
Question 2: Obviously after I get rid of the texture I will want to re-texture it. I want to do it myself (hence DIY), but I can't find any resource on the net on what can be done (different types of texture) I saw somewhere spanish knife and it looked pretty cool. Either way - anybody knows where I can see different samples of texture and preferably a how-to on applying it? I don't want orange peel - too simple, and i don't mind hand made textures, so...
OK. thanks to everyone.
Tim.
l1r is offline   Reply With Quote
Old 07-25-2008, 05:07 PM   #2
Drywall contractor
My Drywall dilema
Let me start by asking how old the house is?? Joint compound and ceiling spray had asbestos in it until the mid 1970's. With that in mind, sanding with an orbital sander will take a long time. Go to a rental place and rent a Porter Cable Drywall sander with the vacuum. You can use it on the ceiling too once you get the main texture scraped off. Bear in mind it will take a lot of sandpaper on the painted surface as it tends to clog quickly. You'll still need to skim coat to get things half way smooth before you re-texture. Sorry, but I don't know where to direct you to samples of textures. In this area, almost everything is "slick" finish. Ceiling texture is the norm in older houses, but only spray (popcorn) or stipple. No wall texture. Flat is way easier to patch should the need arise!
Best of luck!
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-27-2008, 07:30 PM   #3
Smile
My Drywall dilema
There are several techniques that could solve your problem. Look in the drywall category on this website and you'll probably have your answer:
Do It Yourself Today.
jholt29 is offline   Reply With Quote
Old 07-30-2008, 11:32 AM   #4
l1r
My Drywall dilema
Best of luck!
House was built in 1956. I am almost certain texture had asbestos, that's why I'm trying to soak it in water before I scrape, so I don't get much/any dust. I think I kinda got a hang of it on the ceiling (a big part was done on Saturday) with a big water sprayer (the kind you pump the pressure into first and then it sprays). That worked much better than a tiny little hand sprayer. Walls are still in progress. They are painted with what looks like gloss or semi gloss, so water does not penetrate through the paint.
I was thinking getting a big jug of paint thinner and working over the walls with that to get some paint off and then water and scraper to get texture off. Any thought on that?
My life just isn't adventurous enough with the rest of the remodel so I had to make it harder with texture changing
Old 07-30-2008, 01:43 PM   #5
Drywall contractor
My Drywall dilema
You may need to go to the paint forum on that one. I don't know how well it would work. I don't think I'd want to try it.
Old 07-30-2008, 02:16 PM   #6
l1r
My Drywall dilema
Would I be better off texturing right over existing stuff? And can I even texture over existing paint? I'm thinking a coat to smooth everything out, let it dry for a while and another coat of my spanish knife or whatever I'll manage to do... That would be easier...
Old 07-30-2008, 03:00 PM   #7
Drywall contractor
My Drywall dilema
You could certainly put a coat or two of mud over the existing texture and get it at least "semi" smooth before doing another texture. How smooth it would need to be would depend on what you go back with. You wouldn't want the old stuff to "telegraph" through. I'd recommend at least two coats (one coat horizontal, one coat vertical). Of course, going to all that trouble it probably just would be a matter of one more "tight" skim and a sanding and you're back to smooth walls. Depends mostly on your finishing ability (and if you really want texture again or not). Be sure to thin your mud.
Old 07-30-2008, 09:23 PM   #8
l1r
My Drywall dilema
So semi-gloss paint won't matter? Do I need to prime walls before I apply a new coat of texture?
I just want to smooth it out. I've seen it done and thought it looked a lot better. Wish I had a picture to show... all walls are basically smooth and here and there you get a round swirl (180 degrees or so). Didn't look like it was too complicated to make either.
Old 07-30-2008, 10:14 PM   #9
Drywall contractor
My Drywall dilema
Though I'm not a paint expert, I believe you would need to prime with a Kilz or Zinzer primer first. Drywall compound is more or less a latex base product. While I've patched and blended to "gloss" type paints without problems, I think "glazing" the entire surface would require sealing with a suitable primer to ensure proper bond. Again, the paint forum may be the best place to get a definitive answer. If memory serves me, you can use oil over latex but not the reverse.
Old 07-30-2008, 10:34 PM   #10
My Drywall dilema
sounds like you are on the correct path to get the results you want.
"Fresh Start" would be my recommendation for a primer. It covers most anything, and will provide an A+ bond able surface to your next application.
The ceiling popcorn was not a 1956 thing... done to hide some cracks sometime later is my bet.
Stay in period for the house... sand texture...smooth...crows-foot...swirl...
it looks silly to try to be something your not...have fun and enjoy your project..
Big Bob is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Drywall - Horizontal or vertical slinku2020 Drywall & Plaster 27 04-08-2010 01:40 PM
Plaster on drywall? bofusmosby Carpentry 7 03-06-2008 08:30 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
