My Ceiling Moves In A Wave Pattern And Not In A Even Line, I Do Not Know How To Fix. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-16-2010, 11:35 PM   #1
Unhappy
My ceiling moves in a wave pattern and not in a even line, I do not know how to fix.
Just got this house from my In-Laws and notice there was nob and tube in the house. I am in process of clearing it out. Up stairs is clear with new wiring. Took en off the plaster and found lats on the walls and ceiling. Small bedroom is smooth all around, but the Master bedroom ceiling is wavy.
If you stand on a latter against the wall you can see that the ceiling isn't smooth straight. How do I get this to be straight when i put up my new dry wall? Please help, because it seems that every corner of this house there's a problem.
Note age of this house is unknown, This is a farm house, has large bolders in basement for structure. If i have a roughly to guess on age would say 1940's maybe.
Was going to put up 1/2 drywall for walls and ceiling but i dont know now.
TheUnhandyman is offline   Reply With Quote
Old 01-16-2010, 11:42 PM   #2
Thumbs up
You should frame it out. Use metal stud framing and leave a gap of about 4" in the new ceiling for wiring to run through!!
spark plug is offline   Reply With Quote
Old 01-17-2010, 11:49 PM   #3
metal studs?
Metal studs? that can help the wave in the ceiling?? How? I was going to add a ceiling fan in the room but with metal studs i cant though.
Old 01-18-2010, 04:07 PM   #4
You can sister some 2 X 4s onto the joist to level out the ceiling.
adave is offline   Reply With Quote
Old 01-19-2010, 10:40 AM   #5
Old School
Willie T's Avatar
How wavy is "wavy"? And for what portion of the room?
Willie T
