Murco 100 Joint Compound - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-09-2013, 10:43 PM   #1
Angry
Murco 100 joint compound
Has anybody had an odor problem with Murco 100 joint compound? It's supposed to be for chemically sensitive people, which I am. We used it in a room 9 months ago and I STILL smell it. I can't use the room yet and am getting very frustrated. I called Murco and they said that the only thing that is released in the air is the water, but there is definitely an odor. I know it's not the paint because we painted another room and didn't use the Murco in there - no smell at all in that room.
cstone9 is offline   Reply With Quote
Old 09-10-2013, 02:34 AM   #2
Rewards Points: 626
Never even heard of Murco 100? were do you live? and there is no odors with joint compound no VOC's so what is it that made you thin you needed this stuff?
Nailbags is offline   Reply With Quote
Old 09-10-2013, 07:48 AM   #3
Rewards Points: 5,974
The only smell I ever had with joint compound was if it was opened not all used then resealed and it soured. I don't see how this could be from the mud after nine months it has dried, cured, primed, and painted over.
Old 09-10-2013, 07:50 AM   #4
Rewards Points: 13,300
What room did you paint?
What did you paint over, sheetrock, plaster?
What condition was it in when you painted?
Did you prime, and what did you prime it with?
What paint and how many coats?
Old 09-10-2013, 03:44 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
I've only ever noticed odors in drywall compound if it got moldy in the bucket or if it froze and then thawed. I too have never heard of any VOC or chemical issues with regular joint compound.
Is frozen joint compound acceptable once it has thawed? Deck Drywall & Plaster 11 01-03-2013 12:12 AM
Corners are cracking as joint compound dries hoffmandirt Drywall & Plaster 6 04-24-2012 10:33 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 06:04 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
