Multiple Problems With New Drywall Installation - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 12:54 PM   #1
Multiple problems with new drywall installation
Hi, we recently had our house lifted above the flood plain here in Guerneville, CA, and the second story of the house was completely rebuilt. The drywall on the new story has many problems: cracks along seams and in the corners, pin holes and bubbling, seams showing, etc.
Our contractor continues to insist that this is "normal," but we haven't had any of these problems on the top story where we did the installation and finishing ourselves a couple of years ago.
Frankly, it looks like crap and is continuing to deteriorate, but he seems to think we are being "nit-picky." It seems to us that the mud is just too thin overall, and the joints were not feathered properly to hide the seams. Also, it probably didn't help that no primer was used before painting. Are we crazy, or is this typical?
Any information you can give us will be greatly appreciated.
etudor is offline   Reply With Quote
Old 11-15-2011, 01:04 PM   #2
Experienced
Jackofall1's Avatar
Hello and welcome etudor, to the best darn DIY'r site on the web.
You are looking at it but it certainly sounds by comparison that your contractor needs to fix the problem. Cracking is either from too much compound or movement, pin holes are not acceptable at all and seams showing through is a sign of a FBN (fly by night) contractor IMHO.
Mark
Old 11-15-2011, 01:08 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Certainly not typical and yes you have reason to be concerned.
Old 11-15-2011, 01:09 PM   #4
Here are a few pictures of the installation.
Multiple problems with new drywall installation-p1030197.jpg   Multiple problems with new drywall installation-p1030199.jpg   Multiple problems with new drywall installation-p1030201.jpg   Multiple problems with new drywall installation-p1030207.jpg   Multiple problems with new drywall installation-p1030209.jpg
Old 11-15-2011, 01:11 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Our contractor continues to insist that this is normal...
What's he been smokin"? That is some shoddy work there, he needs to fix it. Hide your check book.
Old 11-15-2011, 01:28 PM   #6
Experienced
Jackofall1's Avatar
Have to agree with Bud, what is that guy smoken, and where can I get some. That looks like a pure crap job!
Old 11-16-2011, 12:58 PM   #7
A Little Of Everything
Rewards Points: 1,364
Originally Posted by etudor View Post
Hi, we recently had our house lifted above the flood plain here in Guerneville, CA, and the second story of the house was completely rebuilt. The drywall on the new story has many problems: cracks along seams and in the corners, pin holes and bubbling, seams showing, etc. Our contractor continues to insist that this is "normal," but we haven't had any of these problems on the top story where we did the installation and finishing ourselves a couple of years ago. Frankly, it looks like crap and is continuing to deteriorate, but he seems to think we are being "nit-picky." It seems to us that the mud is just too thin overall, and the joints were not feathered properly to hide the seams. Also, it probably didn't help that no primer was used before painting. Are we crazy, or is this typical? Any information you can give us will be greatly appreciated.
The pictures you posted indicate that the problem isn't the drywall. Unfortunately, it's something deeper. Incorrect framing, settling, etc.
As has been said before, hide your checkbook until this is fixed - not just patched, but fixed.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
chrisBC (11-21-2011)
Old 11-16-2011, 01:15 PM   #8
Thanks for your comments, gents. To be fair, the contractor has said that the problems are due to settling. DrHicks, what about the seams that are showing through and the pinholes and generally thin layer of mud? Seems like that is just crappy work to me. As for fixing the problems, would you guys recommend that I ask him to reshoot everything, or just fix all of the problem areas? Thanks again!
Old 11-20-2011, 04:35 PM   #9
Drywall contractor
Rewards Points: 1,070
Once the cracks are there, there's no "reshooting". The tape has cracked and needs to be torn out and replaced. Otherwise the problem will be back in short order....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-21-2011, 02:27 AM   #10
I would agree that anywhere that tape is showing and there are bubbles, this is a bad drywalling job; as well as no primer being used, doesn't sound like a professional. However I didn't see any of that in the pics, so I can't say for sure.
However the big cracks in the picture to me indicate a problem with settling/movement in the houses framing, I don't see those being a problem with the drywall installation, but rather another issue that is structural, the reason the cracks occur is movement in the structure.
chrisBC is offline   Reply With Quote
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Energy loss due to multiple problems chrisb4 Building & Construction 3 09-26-2009 05:32 PM
Multiple problems in 3 year old house I just purchased swenard Plumbing 12 08-31-2009 04:53 PM
Drywall installation...longer better? gone_fishing Drywall & Plaster 9 01-10-2009 03:46 PM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 01:26 AM
