Mudding And Taping - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-20-2014, 09:50 AM   #1
Landlord
Rewards Points: 89
Mudding and taping
Going to be plugging up an opening in my mom's kitchen. Going to put up the drywall, mud and tape of course. My question is...how far up do I go with the tape that meets the finished ceiling? The ceiling is smooth I believe. TIA
cocean is offline   Reply With Quote
Old 01-20-2014, 09:59 AM   #2
Rewards Points: 13,694
Depends on where the hole is.
Old 01-20-2014, 10:00 AM   #3
Landlord
Rewards Points: 89
sorry by opening, I mean doorway
Old 01-20-2014, 10:11 AM   #4
Unless you have really low ceiling there's no need for any tape to be on the ceiling.
Your going to have to add a bottom plate, and in most cases 2 X 4's at the top and sides of the old opening to have something to attach the drywall to.
Add the top and bottom pieces first then the studs.
That way the top piece will be wedged in place and not going to move.
Old 01-20-2014, 12:06 PM   #5
joed's Avatar
Rewards Points: 12,852
Cover the entire joint. If the joint goes all the way to the ceiling then go all the way to the ceiling with tape. You could stay back 1/8 or 1/4 inch to avoid messing the ceiling if you want.
Durock / insert mudding question Trucon01 Kitchen & Bath Remodeling 2 04-04-2013 10:34 AM
taping and mudding behind shower stall BobLoblaw Drywall & Plaster 5 04-07-2012 03:41 PM
taping and mudding backerboard in a shower kathyll Building & Construction 3 07-09-2011 05:53 PM
Dry Wall mudding mmohanna Building & Construction 3 11-21-2009 07:34 PM
Taping inside corners....one side at a time? yummy mummy Building & Construction 10 07-23-2008 02:23 PM
