Mudding Problems - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-12-2013, 11:41 AM   #1
Mudding problems
Poking for feedback on the GNC Synko Drywall compound that is the latest and greatest. We have a problem with some seems cracking what have we done
franklea is offline   Reply With Quote
Old 01-12-2013, 05:54 PM   #2
Rewards Points: 512
i know nothing about that kind of drywall compound. what did prefill your joints? did you use mesh or paper tape? or tape at all? what areas are cracking? how thick did you apply the mud?
princelake is offline   Reply With Quote
Old 01-13-2013, 02:38 PM   #3
We used a mesh tape and have on many projects and reno's. Some of our seems developed hairline cracks after we primed. We have spoke to the company and of coarse have no response or advise other than "read the bucket"
Old 01-14-2013, 09:10 AM   #4
Rewards Points: 5,974
Have never used or heard of that mud. Now are the seams your talking about in the corners or are they your flats. If it's your flats then was your fill and first coat hot mud? If it was then it sounds like maybe you put it on to thick. If the problem is the angles then the mesh is the problem, it doesn't have a crease like paper so it is almost impossible to get good corners. also it is very easy to cut with your knife when you are mudding. Therefore losing it's strength. Maybe you just use a light weight mud for every coat. There are many things could cause this a few more details would help.
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Owen or Certain Teed has less problems?? reeses Roofing/Siding 10 02-07-2009 09:35 PM
Determining whether or not you have foundation problems? rmartin1286 Building & Construction 8 01-23-2009 09:09 AM
steam heat problems alanliz HVAC 8 01-18-2009 09:10 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
