Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-02-2010, 09:37 AM   #1
Question
Mudding drywall with wood
Whats up guys hope all is well. I hope some of you can answer this question or steer me in the right direction. I have a couple of stairs coming down from my kitchen to my landing then leading to my basement. Along the side of the stairs from the kitchen to my landing is wood met up with drywall. I don't want to put any trim because it will stick out and i would perfer a flat serface could I mud that joint or would I run any kind of risks of whatever. Thanks and have a great day
mjannoun is offline   Reply With Quote
Old 06-02-2010, 10:50 AM   #2
Handyman
You can mud it but I advise filling the crack with Durabond first. That way it is less likely to crack.
canadaclub is offline   Reply With Quote
Old 06-06-2010, 02:18 AM   #3
yes you can do whatever you want.
better would be to use a tear away bead,
better yet would be to laminate it with 1/4 inch
your way might work but theres no guaruntee how long it will last.
are you butting sheetrock to the skirt board?? id use some sort of bead for a better look.
oldrivers is offline   Reply With Quote
The Following User Says Thank You to oldrivers For This Useful Post:
oh'mike (06-06-2010)
Old 06-12-2010, 11:38 AM   #4
Drywall contractor
I have used joint compound on wood before as a light skim to fill imperfections (at the painter's request). It will adhere to the wood, but I can't say for certain for how long. He apparently didn't think it was a problem....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Fire rated drywall over wood stove? RyanD Drywall & Plaster 3 07-21-2009 12:19 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
