Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-05-2011, 11:39 AM   #1
mudding on drywall
I have a couple of questions.
1. what is the best way to tape and mud the joint where the hardibacker and the drywall meet?
2. part of the drywall will be painted and part of the drywall will be tiled on. What do you use for the tiled part for mudding - thinset or regular drywall mud?
kathyll is offline   Reply With Quote
Old 07-06-2011, 01:25 PM   #2
Drywall contractor
mudding on drywall
Best case scenario would be to kill the edge where the hardie and drywall meet with a bullnose tile piece that laps onto the drywall. If you must finish it, I'd use mesh tape and setting type compound for the first coat (at least). Again, I'd go with a tiled edge if at all possible....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Mudding drywall with wood mjannoun Drywall & Plaster 3 06-12-2010 11:38 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Drywall Mudding Challenge: Seam vs. Tapered Corner cjakins Drywall & Plaster 3 03-10-2009 01:41 PM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 2 09-22-2005 01:03 AM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 12:53 PM
