Mount 10-15 Lbs. On A Drywall - What Screw Anchors To Use? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 01:29 AM   #1
Wek
Mount 10-15 lbs. on a drywall - what screw anchors to use?
I'm trying to mount a 10-15 lbs light fixture to a drywall. I have never hung anything so heavy on a drywall and I'm afraid I might do it improperly and have it fall to the floor and break. Can anyone tell me which anchors I should use to have such a heavy object mounted properly?
Wek is offline   Reply With Quote
Old 03-01-2011, 06:03 AM   #2
Is it on the ceiling?
If so, is the box that houses the wires attached to a stud? (should be)
In the light fixture packaging and instructions, does it screw tot he junction box in the ceiling? If so the box attached to the stud should support it just fine.
williamwiens is offline   Reply With Quote
Old 03-01-2011, 06:34 AM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
we need a little more info on this. do you have any picts of what you are trying to mount. 10-15 lbs isn't very heavy. A single 1/8 toggle bolt will hold more than that in 3/8" drywall
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 03-01-2011, 01:45 PM   #4
Wek
The lamp would be on the side wall, the ceiling is concrete and has that "popcorn" surface.
Here's a picture of what I would be mounting:
I would be converting the light fixture into a pluggable lamp. The lamp is 4 feet long and about half a feet wide.
If you need more info just ask, I have never done this so I'm not sure what kind of info you might need.
Btw, how many screws do you think it I would need to safely mount this? 2?
Old 03-01-2011, 02:01 PM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
if it's going on the wall horizontally and is 40" long, then just figure out where your studs are and drill two holes in the sheetmetal so that they fall over the two studs it will span and screw it on into the studs. Simple and sturdy
EDIT: if your ceiling is concrete then there is probably concrete behind drywall (assuming it's an exterior wall). do you know what is behind drywall? that thing can't weigh much, two fasteners should be plenty regardless
Old 03-01-2011, 03:37 PM   #6
Wek
What id I can't locate the stud? I don't know where they are or how to locate them.
What if I drill anywhere and just use the toggle bolts? Would the drywall rip over time?
Old 03-01-2011, 04:23 PM   #7
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
No, the drywall won't rip unless you are trying to sit on the light fixture.
The only problem you might have is depending on how it's framed, there might not be enough of a void for the toggle wings to open ( if it's an interior wall you should be fine).
here's what I suggest: hold the fixture against the wall EXACTLY where you would like to put it. Take a pencil and poke it through the screw holes in the fixture, so you make a mark on the wall. Put the fixture down, then take a 3" nail and LIGHTLY tap it through the drywall at each of your two marks. Once it goes in about 1/2", see if you can easily push it all the way to the head. Then kinda wiggle it around on an angle to make sure you aren't too close to anything. If you can't feel anything inside the wall and the nail goes easily into the wall the whole length you should have a big enough void and should be just fine using a 3" toggle bolt. Use the nail holes as your pilot holes and drill out to the correct size. Two 1/4" toggles will easily hold 10 of those fixture up with no problem in even the thinnest drywall
Oh, and to answer your question, yes, you could just grab a drill and bore a couple holes "anywhere" , but you won't know if you drilled into an electric wire or water pipe until it's too late!
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 03:13 PM
Removing built in drywall shelves to wall mount TV homerb Project Showcase 0 05-19-2010 12:34 PM
Drywall Bulge after installed TV wall mount tstecko Drywall & Plaster 15 03-23-2010 07:35 PM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
