Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-17-2011, 01:25 PM   #1
moulding between panels
i live in a mobile home and i need to know what the moulding is called that hides the gaps between drywall panels. ive thought about removing them and mudding the gaps but im not very good at it. id like to replace the moulding with something narrower or lower profile so it wont be as noticable.
showard is offline   Reply With Quote
Old 05-21-2011, 05:08 PM   #2
If you move your home those joints will mostly likely just pop and crack if they are taped and filled. That's the reason they use the trim pieces. Can't you find anything at a building supply store? If not look in the yellow pages for a Commercial Wall and Ceiling Supplier.... they'll most likely carry all sorts of different types of trims.
dberladyn is offline   Reply With Quote
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 09:26 PM
Building Fence on a Slope with Panels... help please. acchan01 Building & Construction 11 09-29-2010 03:15 PM
Door Moulding Idea Help Vibber Carpentry 4 06-01-2010 08:51 AM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
